w203 radiator fan wiring c220 cdi coolant visit workshop
Old 08-05-2012, 07:12 AM
Guddu05's Avatar
C220 CDI SPORTS COUPE 2001
Unhappy w203 radiator fan wiring c220 cdi coolant visit workshop
Hi All
I have a Mercedes c220 cdi w203 sports coupe evolution
It has been displaying Coolant Visit Workshop.
I have checked the sensors coolant and washer bottle sensor, they are fine but I think my fan wiring is fault.. I have the following Wires :
1. Thick Red (Positive v12+) working fine
2. Thick Brown (Ground), some models can be black
3. black/white stripe (ignition from what i have researched) No power
4. green/blue (remote) this has 3.5 v when ignition switched on..
Usully the ignition should have 3.5 volts, why does my remote wire have this volt??? or on my model the remote wire is ignition???
I am baffled, any merc experts that can help?? My fan is not turning on at all, the car is not over heating, thermostat is working as well.
Also how does the AC work as on my controls I dont have an ac button i have ec and auto etc but nothing that says ac.. but looking at the engine i have the ac system including the pump and pipes..
I have one big radiator fan. Help me out guys I need to solve this problem so I can drive the carr
Old 05-01-2014, 09:23 PM
drm
drm's Avatar
Would you able to share the solution to your particular issue?
I hope it was a simple fix.
Old 10-24-2014, 11:33 PM
parasite69's Avatar
C32 amg
Cooling fan nightmare
I've got a c32 with the same probs. new cooling fan, new front Sam, ECU checked ok, new temp sensor and new ac sensor and still the fan doesn't work. Merc suggested a chafed wire in the engine bay. Still havnt found the problem. If you have a solution please share.
Cheers
Old 10-25-2014, 08:21 AM
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
I just want to share my experience in case someone looks for this in the future. I had coolant visit workshop a few weeks ago and was worried it was the fan. Car temp would rise slightly to maybe 100C then drop back to normal op at 90C each time the warning would come one.
I researched on here for a long time to figure out the problem and found a lot of cases where people replaced the fan but the fan wasn't the problem. I replaced my thermostat and coolant temp sensor since they were cheap parts anyways but the message was still there.
I was planning on replacing my water pump and rad hoses this winter as PM anyway since the car just clicked over 100k recently, so I went ahead and bought that and replaced it, and problem was solved. Turns out the car somehow knew that the water pump was starting to fail, not sure how as there are no electrical sensors in the water pump itself, maybe pressure sensor somewhere picks up on it. But anyways, $85 for a new water pump is much better than $600 for a new fan. So anyone who has pretty high mileage and hasn't replaced their water pump yet, maybe look into that before the fan. And while you're at it, it's not a bad idea to just replace the radiator hoses too so you know everything is nice and new with the cooling system.
Old 10-25-2014, 04:23 PM
drm
drm's Avatar
Solution to my cooling fan problem
It turned out that the problem I had was a simple damaged wire in the harness. When we initially scanned ECU, we were unable to perform a test or activate the fan. Sometimes these's wiring issues take a great deal of time to find but it beats replacing unnecessary parts.
Old 03-04-2022, 04:57 AM
verlin samonte's Avatar
E200 2002 kompressor
would u know which area the damage was found , maybe same area a with my problem
Old 03-04-2022, 11:11 AM
drm
drm's Avatar
I believe they tested the wire connection from the fan to the fuse panel and found no connection or continuity. The damaged wire on my car was in the wiring harness just outside the engine fuse panel. Testing the connection/continuity should identify any break in the wires. I hope that helps.
verlin samonte (03-05-2022)
Quick Reply: w203 radiator fan wiring c220 cdi coolant visit workshop
