3000 stall Torque converter special C32/722.6
PLATINUM SPONSOR
3000 stall Torque converter special C32/C55 with 722.6
We ran 4 extra 3000 stall converters set up specially for the power and Torque range of the C32.
A Few Specs,
3000 stall RPM
10 lbs lighter than stock (less rotating mass for engine to turn)
HD Torrington bearings to reduce drag
3 HD Raybestos locking clutches VS the weak 2 clutches
HD internals parts
List 1095 and for the C32 special, we have 4 at $850.00to your door (cont. USA). PM me for specifics or dealing is welcome on this special as well
A Few Specs,
3000 stall RPM
HD internals parts
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Steve Koss (04-13-2020)
PLATINUM SPONSOR
The 30% lighter converter will also free up power and help the engine rev quicker. These are locking converters, so they lock up at low speeds and are very streetable or trackable. If you set up your car for road course work, then this converter could be a nice advantage over other autos in your class.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
No ECU tune is needed as the converter does not effect air fuel, timing or boost at all and TCU is also not needed, unless you just want custom shift points or raise shift rpm, etc for street or strip needs.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Around 300 ish.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Anyone interested, PM me your offer. We have been running this set up in several C32`s and C55 for a while now. A good converter like this is a game changer
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
PM me your dyno (or post it) and I will match your car up with the right stall, based on your peak torque. If you are still naturally aspirated, then your torque will come in a little higher and a converter will be a huge benefit for you set up. We have them in stock and can ship the same day.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Have two left now for the C32 or C55. PM if you want a stall converter.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
