W203.076 C55 Specific Part Number Database
Hello All,
For the past few months, I have been repairing and fixing up things on my 2005 C55. I started a Google spreadsheet document to help me track my expenses and log the part numbers I used. This forum (with the search tool) has been really helpful, but I wanted to consolidate the part number data into one place.
As you know, as time goes on, part numbers are super-ceded, this is why it is always best to get your part numbers from the online (and free?) Mercedes-Benz EPC (Electronic Parts Catalog) (http://epc.startekinfo.com/epc/welcome.jsp), but perhaps my spreadsheet can help some of you get a leg up on some research for your various repair and upgrade projects.
If you would like to add some numbers to my spreadsheet, please PM me with what you have. I will double check your numbers and then add them to the document. I intend to keep it updated as long as I own my C55. (Which, with all this money being spent, is basically until the M113 explodes.)
(See my signature for the link to the document.)
Thank you,
Rahul
Thank you,
Rahul
Last edited by Rahulio1975280C; 10-17-2014 at 11:55 PM. Reason: Added link to document mentioned in post.
Nice.
You upgraded to the 6/4 brakes? I didn't know that you had.
Also, you got any more of the sunroof grease left? I'll pay ya for some
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
Nice spreadsheet
I just did a bunch of cooling system stuff this past weekend. Feel free to add these. All prices are from RM European.
Thermostat (includes seal) - 112-203-02-75 - $23.25
Thermostat Seal - 112-203-0076 - $1.93
Water Pump (Graf) - 112-200-14-01 - $87.82
Water Pump Pulley - 112-202-01-10 - $31.90
Lower Radiator Hose - 209-501-28-82 - $110.23
Upper Radiator Hose - 209-501-06-82 - $71.55
Radiator Hose Exp Tank to Rad (connects to upper hose) - 203-501-26-82 - $20.57
Water Hose Oil Cooler to Pump and Oil Cooler to Timing Cover (2 total needed, I only replaced the one to the pump since I didn't remove the other one while installing the pump) - 112-203-03-82 - $2.72 each
Radiator Hose Seals for upper and lower hoses to radiator (note if you buy the upper and lower hoses they will come with the o-rings on them) - 026-997-68-45 - $5.27 each, 2 total
Coolant Level Sensor - 220-545-00-24 - $17.26
Coolant Temp Sensor - 099-905-38-00 - $19.10
Coolant Temp Sensor Clip - 008-988-91-78 - $2.24
Transmission:
Trans Filter - 140-277-00-95 - $12.66
Trans Pan Gasket - 140-271-00-80 - $8.49
Trans Mount - 212-240-04-18 - $31.97
Engine:
Engine Mounts (2) - 220-240-06-17 - $100.77 each
Drive Belt Tensioner - 112-200-09-70 - $131.80
Idler Pulley - 000-202-09-19 - $16.59
Crankshaft Sensor - 003-153-28-28 - $45.29
Camshaft Sensor - 272-905-00-43 - $52.39
Timing Chain - 003-997-68-94 - $88.14
Timing Chain Tensioner - 112-050-08-11 - $70.32
Power Steering Pump - 002-466-98-01 - $346.95
Valve Cover Gasket Left - 113-016-02-21 - $11.62
Valve Cover Gasket Right - 113-016-03-21 - $11.48
Engine Oil Cap Seal - 111-018-00-80 - $1.69
Intake:
MAF Sensor - 113-094-00-48 - $190.24
MAP Sensor - 005-153-50-28 - $33.54
Intake Manifold Gasket (2) - 113-141-09-80 - $5.72 each
Breather Hose Valve Cover to Intake - 112-018-04-82 - $8.82
Breather Hose Top Section - 112-018-03-82 - $7.16
Breather Hose Center Section - 112-018-02-82 - $4.89
Breather Hose Bottom Section - 112-018-01-82 - $6.99
Transmission:
Engine:
Intake:
I will send you a PM for the grease.
