How to check voltage?
Old 11-23-2014, 02:38 PM
AMGPirate's Avatar
2006 C55
Hi Guys - can anyone tell me how to check the voltage on our cars? I thought there was an on-board feature but for the life of me I can't figure it out.
I'm thinking of doing a preventative voltage regulator change (120K miles) and just wanted to look at what the system is currently putting out.
Thanks!
Old 11-30-2014, 08:05 PM
Tump43's Avatar
2014 E350 4Matic
Your question is answered in a "MB Reset Service Indicator Guide" that probably posted in these forums a while ago -- which I copied:
"Models 203 and 209 (C-Class and CLK-Class)
1. Insert key into ignition, switch to position “1“.
2. Press buttons or repeatedly until the mileage is displayed within the Multifunction display.
3. Press cluster illumination button (1) 3 times in short succession. The battery voltage will be displayed and an audible signal will sound.
4. Turn key in ignition to position “2”
5. Press the up / buttons until the service menu appears.
6. Press cluster illumination button (1) once. The Oil Type menu is displayed.
7. Use the and buttons to select the oil used for the service.
8. Press the up / buttons to confirm. The display will show: “Reset Oil Confirmation. Push R-Button for 3 seconds”.
9. Press and hold the cluster illumination button (1) for 3 seconds. The message “Service confirmed” is displayed.
Note: "1" is simply the reset button at the bottom of your gauge binnacle.
Quick Reply: How to check voltage?
