Do I Need Fuel Injector O Ring and Seal Service For My C55?
2003 W211 E500
C55 Fuel Injector Rebuild Kit Available? Please Help
I have an 05 C55 and am looking for a rebuild kit for my injectors. I cannot find any info on rebuilding them and don't want to pull them apart without the proper instruction. The part number is 0-280-156-074 . Any info on this will be appreciated.
2016 E350 4Matic; 2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
It's a run of the mill Bosch injector. As far as a rebuild kit goes - nothing is available that would allow rebuilding as the injector is a sealed unit. You could replace the o-rings, if those are dry or cracked and allowing false air. You could send it off to be cleaned - but not recommended. Best bet is to replace.
2003 W211 E500
I ended up changing the O-rings and the filters but the universal filters did not fit so I had to mod them. I just do not have the money for new injectors. Thanks for the reply
