C55 Maintenance at 135k Miles
Old 02-19-2015, 01:51 PM
AMGPirate's Avatar
2006 C55
Hi All - I've owned my C55 for about a year now and it has been the most reliable car I've had to date. (knocks on wood).
For those in this general ballpark mileage wise - what have you done as far as preventative maintenance goes?
I recently did new front rotors/pads, engine/trans mounts, idler pulley, belt, coolant flush, plugs/wires, and air filters. I like working on cars and usually try to keep a good preventative maintenance routine.
I noticed while changing the idler pulley that the tensioner pulley is shot too. Am I right in understanding the pulley alone is not replaceable? The whole tensioner assembly with pulley needs to be changed together?
I'm thinking about doing the water pump/thermostat as well "while I'm in there". Is that silly on these cars? I come from the audi/BMW world...and we usually replace those items around this mileage (if not sooner).
Thanks!
Old 02-20-2015, 06:49 AM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
The tensioner only comes as the whole unit (at least from Mercedes) when I had replaced mine. I wouldn't worry about the water pump or thermostat, I don't believe I've heard of but one or two water pump failures on here. I would definitely do a transmission filter and fluid change.
Quick Reply: C55 Maintenance at 135k Miles
