C55 P0442 "Small Leak Detected"
Old 03-27-2015, 09:28 AM
Quickvr4's Avatar
05 C55 AMG
I have recently been getting the P0442 code, "Small leak detected". For those who have been through this process, what parts do you recommend I look in to replacing and in what order?
Thanks,
Derek
Old 03-27-2015, 01:04 PM
WaveyKat's Avatar
Something Slow
gas cap, Fuel Neck .. you need to do a smoke test..
Old 04-06-2015, 08:52 PM
Quickvr4's Avatar
05 C55 AMG
New gas cap is in....will wait and see how it works out.
Old 04-06-2015, 08:59 PM
greekspec2's Avatar
2005 C55
N80/EVAP valve next to ABS pump
Old 04-09-2015, 10:49 PM
Quickvr4's Avatar
05 C55 AMG
I can smell a gas leak when I park the car in the garage. Would the EVAP valve cause this or is it most likely the filler neck?
Old 04-10-2015, 08:35 AM
Dollos's Avatar
Mercedes C32
Can someone please post a pic of the evap valve next to the esp module?
thanks
Old 04-10-2015, 09:05 AM
greekspec2's Avatar
2005 C55
https://mbworld.org/forums/c-class-w...lve-issue.html
Here's a link with a pic, this part is very common on most european cars and we replace them at Audi alot, it basically controls/ allows fuel vapors to purge into the intake manifold vacum for combustion instead of into the atmosphere, and it's suppose to tick which is the diaphram opens in miliseconds to purge from canister when the ecu monitors it
Old 04-10-2015, 09:22 AM
Dollos's Avatar
Mercedes C32
So this guy shouldnt tick. Mines been ticking since i bought the car. no codes are coming up.
what type of failure will this guy cause?
thanks
Old 04-11-2015, 12:55 PM
greekspec2's Avatar
2005 C55
it should tick but the diaphragm/valve go bad allowing a small leak
Old 04-13-2015, 03:18 AM
Dollos's Avatar
Mercedes C32
Ahh ok Thanks guys for the info
Quick Reply: C55 P0442 "Small Leak Detected"
