Steering column travel problem
Old 04-04-2015, 10:54 AM
mcelroyx's Avatar
2005 C55
I have an '05 C55. The positive battery terminal became loose and allowed the battery to die. I have successfully reset the window and sunroof travel but the steering column does not want to reset. It will move up and down just slightly (maybe 1 cm) and I have tried the reset procedure numerous times. Does anyone know of a different reset procedure I should be following? It seems like the motor and switches are functioning. Thanks for any help. __________________
Old 04-07-2015, 01:56 PM
raphman's Avatar
'16 C63s
I'm having the exact same issue... so subscribing in case someone has a fix. The in/out adjustment works flawlessly, but the vertical is VERY limited, maybe 1/4" or so.
Old 04-08-2015, 09:37 AM
dsp_tdi's Avatar
2005 C55
I had a same problem.
I remove the adjustment of steering column and I re-adjust to put the column at the higher position and after the steering column go up and down (full travel).
Is not a easy job!
To help you!
https://mbworld.org/forums/audio-ele...e-up-down.html
Old 04-08-2015, 04:52 PM
Saaboteur's Avatar
eclectic assortment of cars
Good link! I remember reading rumours (so people posting that they had seen it or heard of it being done) that knowledgeable a tech managed to install the new 'dogbone' with a pair of long needle nose pliers in 5 minutes, without disassembling the dash. Would like to know more about that procedure!
Quick Reply: Steering column travel problem
