C32 AMG ERROR CODES P0720, p0600, p0111
Hey guys, need some help with my 2003 C32 AMG.
ran it the whole summer nicely almost 7k until i have this new issue total mileage is 195 000 km
SYmtoms
engine light came on
feels like a loss of power of almost 50% I can't blast off after 2nd gear it feels
weak like no acceleration, if i hold down the pedal the rpms go up slowly
1 malfunction I've always had. check coolant. malfunction shows after overnight
when temp go down a bit.
this malfunction goes away after driving. I find this a bit strange since its parked
in an underground parking lot and this still shows every morning.
other than that i replaced the fuel pumps 4 months back.
when car is at traffic light or parked. i see theres a bit of a rough idle. needle goes up and down so slightly that its not noticeable unless you really look closely.
you can feel a slight rumbling if your sitting in the car but barely noticeable.
codes that i got with the scanner
ERROR CODES P0100 INtake Air Temperature Circuit/range/ performance problem
P0720 Out put speed sensor circuit malfunction
P0600 Serial Communication LInk Malfunction
Please help anybody!! where to go from here!!
My IC pump supposedly was replaced before i got this vehicle
ANYTHING HELPS thanks Guys.
SYmtoms
No I don't, Coolant seems to be at the proper level. now I've noticed it stays on during driving. Check coolant malfunction.
Im wondering if it could be the Ic Pump even though it was replaced supposedly from previous owner with a bosch one i believe.
