C32 TRANSMISSION PROBLEM
2003 C32 ONE DAY THE TRANSMISSION WOULDNT ENGAGE. WHEN I FIRST START THE CAR IT WOULD ENGAGE FOR ABOUT 10 SECONDS AND THEN JUST DIE OUT, NO MORE MOVEMENT IT WILL JUST REV OUT. REPLACED THE CONDUCTOR PLATE AND VALVE BODY. I DONT KNOW WHAT ELSE IT COULD POSSIBLY BE. CAN SOMEONE PLEASE SHED SOME LIGHT.
did you look at the TCU? did you change the harness plug? Have you had car car scanned on a star scanner? Id the fluid at the right level? are you using the correct fluid? Car ever flooded?
Believe it's due to glycol contamination due to the Valeo radiator
Former Vendor of MBWorld
This PDF link
http://www.all-trans.by/assets/site/...es/722.6.1.pdf
is the best troubleshooting manual I am aware of for the 722.6 trans. It was compiled by ASTG. It can assist you with verifying fluid level, verifying shift lever assembly is sending correct info to TCM etc. I think this manual will help point you in the right direction
--Kyle
