Front 6-pot calipers from SLK55AMG. Can I use 345mm brakes?
#51
00 C200 & 00 C55 & 06 SLK55
Yes, they will fit, you will need around (4mm) washer between the caliper bracket & the bolt hole in spindle, to balanced the Rotor in the center of the caliper,
and it will be approx. (5.5mm) gap in the Rotor Ring (that pad will NOT surface it),,
cause the center dia. of "C32/C55" Rotor Hat is (226.5mm), while center dia. of "Clk55/Slk55" Rotor Hat is (218mm)..!
,,ZAYED,,
,,ZAYED,,
