Drivers Seat
C32 AMG W203
Drivers Seat
Hi all the drivers power seat and steering electrics have stopped working the scanner will not recognize the drivers seat it recognizes the passengers seat and all works fine which it does all the fuses are good can i assume the module under the seat is at fault ? Car is C32 AMG W203 2002 model right hand drive as im in the UK Hope you can help.
2003 Magma Red C32 AMG, 2003 Silver C32 AMG
This happens to me sometimes and it should be an easy fix. Go under neither your seat and unplug and re plug the plugs into there correct spot on the seat controller box. After that retry it. Most of the time, the seat gets to low and it creates the wires to be pushed together which apparently sometimes makes the port comes loose. Let me know if it worked.
