Climate control unit
#77
#78
1 Post
1998 Black Opal C43
If you're doubtful, just give it a shot. Worst case scenario is it stays the same.
#80
1 Post
1998 Black Opal C43
I'll keep you posted. The weather here is rainy now, so generally I think the temperature is a little up, but will keep an eye on it.
#81
this might be a cheap solution to tighten the screws and not having to buy an expensive replacement unit.
i wish you good luck with your display it will work now.
i will try this next spring when i take my car out from her winter beauty sleep
#83
#85
all this time after you fixed the lcd, did the display work perfectly?
maybe your suspension is to stiff and bouncy giving your panel a hard time?
maybe this shop sells ribbons for lcd?
http://www.akspeedo.com/
#88
#90
Same issue with the fading numbers. I just ordered a climate unit off ebay for $50 shipped. Didn't see this thread though...
Is the quick fix working? Maybe some electric grease on the connections and locktite on those threads would hold it in better.
#92
if you bought a used one off ebay you're likely screwed, this HU looks good and works while junkman strips the car in parts but the problem mostly occurs when you drive the car, then you will notice if it's good or bad from vibrations when you drive!
we will all eventually suffer from these inferior quality head units!
buying a new one for high price at stealership is the only way to go if you can't find a cheaper vendor?
#94
#95
Climate Control Unit came in the mail a couple of days ago, $50 shipped. Popped it in and works beautifully. Let's keep our fingers crossed. I guess I'll play with the old unit when I have some time.
#96
OK so the new unit doesn't have an issue with the LCD, but the backlight is flashy. I'm going to pull it out and replace the bulb (think I read somewhere I can do that), but otherwise works fine. I can probably just use the bulb from the unit with the bad LCD/wire.
#98
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Check the connection to the bulb first. Could be the plug, but keep a spare bulb around.
