Sign in using an external account
| C36 AMG, C43 AMG (W202) Discuss the C36 and C43 AMG. |
LinkBack | Thread Tools | Search this Thread |
Rating:
Display Modes |
#26 | |||
Drives: 1998 c43 to w202 C55 coversion, 95 Eagle Talon TSI AWD,99M3,94 332i
__________________
5.5L converted monster W202 C55 Talon TSi 4 cyl V8 V10 assasin! ![]()
#27 |
Drives: Obsidian Black C43/55
Correction.... The engine you source retains the oil pump portion that bolts to the block because the 43 one doesn't mate up correctly. The pickup is swaped and the upper oil pan needs to be ground down slightly where it contacts the pump. Nothing that will affect the sealing just to allow for clearance.
I can't believe no one has run in to that issue and posted. Or maybe they did and chose not to. Any information put out there that helps in making decisions with the direction you want to go with your car is good info. |
#28 |
Good info since my engine is from an S55. I won't be working on it until I move in the Spring. Thanks.
__________________
Eric 98 C43 + Other toys
#29 |
Drives: eclectic assortment of cars
Money-one, what about the 55 engines from W203 C55s and R171 SLK55s? Do you know if these will pop right in as well, or will the same sump issues come into play?
__________________
88 Saab 900 Turbo SPG - the 'SAAB0TR' - SDS/OZ/Wilwood/Koni/Abbott/Kinetic GT30R - Sold 74 Saab 99LE - rallycar - Sold 01 Honda S2000 - J's Racing/Tanabe/KW/Mugen/Powerflex/Enkei/Stoptech/SOS supercharged 99 Mercedes-Benz C43 AMG - Vogtland/Bilstein/KMac/C32/55 OE big brakes/'55' swap on the way - Sold, but not gone 05 Mercedes-Benz C55 AMG - '63' paddle shifters 02 Audi A4 Avant Quattro 1.8T - APR Stage 1+ 06 Land Rover LR3 HSE - wife's ride AMG Orphans Club International #8 |
#30 |
To be honest I don't run across many 171,203,463 55's but it pretty much applies to the other vehicles.
If you find an engine from a ME 2.8 and are going to swap harness to retain the ME 2.0 their are two different components with different connectors. The throttle body and the coil packs. Just check these prior to disposing of the 43 engine. Also check your alternator connections |
#31 | |
Quote:
Okay! How about this one, is this the fitting you mean?
__________________
#32 |
Drives: 1 out of 1125 C43's imported to U.S.A
I have PM'd the moderators to make this thread a sticky as there is good info in this thread. Everyone should PM the moderators until they make this thread a sticky.
__________________
#33 |
Yep that's it!!!
__________________
#34 |
Yay for the thread being made into a sticky!
![]() I was going to edit one of my first posts to consolidate some of the information from Money-one and ProjectC55, but looks like it's not possible now because of time elapsed. So instead, here are those few tips mentioned: The heater core feed connector from the C43's head must be swapped to the 55 engine's head (see posts #10, 13, 31 and 33 for deets - thanks to ProjectC55 for this info). W210 E55 and W208 (209 too?) CLK55 engines are 100% drop in, and thus most desirable. However, engines from other acceptable donor cars should not be ruled out, as they will just require a bit of work to fit, due to potential front roll bar clearance issues (see posts #22, 25 and 27 for details). Thanks to Money-one for this info. Also, if the donor car is equipped with Bosch ME 2.8 engine management (as opposed to the C43's ME 2.0) then one must keep a keen eye on the throttle body, coil pack and alternator connections on the engine wiring harness. The 2.8 connectors are different from the 2.0 connectors. If the donor engine is stripped already, then one must 'dress' the engine with the C43's accessories anyway, so not a big deal. However, if the engine is already dressed, then it is likely that these few components may need to be swapped over from the C43's original engine to ensure everything connects and fires up when the 55 is dropped in. Clearly, it is much easier to swap components on an engine when it is out of the car, as opposed to doing it in situ. From previous experience with my Saabs, something that is a 10 minute job when the engine is out can be 2-3 hours (and a whole lot more cursing) with the engine in the car simply because of the lack of space. Thanks again to Money-one for this info, and see post #30 for details. Also, Money-one has suggested replacing the circulation pump and idler pulley with the engine out, again for ease of installation with the engine out as opposed to it being a pain with the engine still in the car. See post #22 for details on that. Finally, a conclusive note on engine management. Years ago, I knew a guy who desired to swap a motor from an E46 3-series into his '88 E30. I don't know enough BMW nomenclature to give details of the swap, but if memory serves, the donor car was an early '00s straight 6 with 200ish hp. My mechanic friend (not the owner of the car) actually did the work. I remember him literally sitting there for two full days with the original wiring harness pulled apart, being mated up to a harness off the donor car. It was a nightmare, and a testament to my friend's capabilities that the car ran faultlessly - and the original gauges all worked! - however it was not something I wished to do. Ever. However, as outline by ProjectC55 in another thread (http://www.mbworld.org/forums/c36-am...ce-5-4l-2.html), and in post #16 and elsewhere in this thread, the C43's stock engine management can stay in place. At the very minimum, his car, plus of course Money-one's originally, Speedybenz and c55m8o (from the club202 forums, don't think he posts here much anymore) run their cars with the original engine management (and transmission). I'm still impressed by how 'malleable' the standard engine management apparently is, being able to accommodate another 1100cc displacement. But hey, if it works for them, then it should work for everyone. It should be noted that Money-one's car is not running a naturally aspirated 55 engine anymore; rather he has transplanted the supercharged 55 motor into his car. That swap is outside the bounds of this thread, as it involves quite a bit more work, especially on the engine management side. With most swaps, physically bolting the donor engine into the original car is the (relatively) easy part, and sorting out engine management is the hard part, especially with modern electronics which integrate other features (braking, transmissions, stability control, traction control, etc). The C43 '55' swap requires none of this tomfoolery, therefore making it easy-peasy, lemon-squeezy. I am hunting for a suitable engine as we speak! ![]() Next, I wouldn't mind hearing some input on the swappability of transmissions from other cars. From what I gather, the W210 E55's transmission will bolt in. I suspect the CLK55, SLK55 and W203 C55 would also go into the C43, but they would likely lose their 'Speedshift' function. I doubt the ML55 or G55's all wheel drive transmissions would work, but it would be lovely to have an all wheel drive, W202 C55 - it would really wipe the smiles off S4 owners....
__________________
88 Saab 900 Turbo SPG - the 'SAAB0TR' - SDS/OZ/Wilwood/Koni/Abbott/Kinetic GT30R - Sold 74 Saab 99LE - rallycar - Sold 01 Honda S2000 - J's Racing/Tanabe/KW/Mugen/Powerflex/Enkei/Stoptech/SOS supercharged 99 Mercedes-Benz C43 AMG - Vogtland/Bilstein/KMac/C32/55 OE big brakes/'55' swap on the way - Sold, but not gone 05 Mercedes-Benz C55 AMG - '63' paddle shifters 02 Audi A4 Avant Quattro 1.8T - APR Stage 1+ 06 Land Rover LR3 HSE - wife's ride AMG Orphans Club International #8 Last edited by Saaboteur; 09-20-2010 at 02:31 AM. |
#35 |
Drives: 2004 Chrysler Crossfire
I am envious of you guys since this really has to be the easiest swap you can do to a MB compared to what I had to do with the Crossfires. I am still running the V6 Trans which is also a 722.6 Trans. It is believed that the V6 Trans has a weaker clutch pack but I haven't been able to hurt it after 10,000 miles. If I were you guys I would suggest you don't change the trans. You already have one that can handle the power and the one you buy may not be any stronger. The 722.6 Trans is also behind the Srt8 hemis. If you change transmission and the gear ratios are different you can run into problems and may have to run a different transmisson computer.
The bottom line is this is a very easy swap if you keep it simple. Any 55 will work. Any part that is differnt can be swaped from the C43 engine. As mentioned above some 55's will require more swapped parts than others. Swapping the part is not a big deal if done out of the car. I did change my idler pulley because it was starting to make some noise. It only takes a minute to change out of the car. If you keep is simple this is a very simple swap. Any decent headers available? the only one I have seen for the C43 is a little bit bettter exhaust manifold. I would get a true header witha collector which is how scavenging is most effective. Headers would be something to consider with the engine out!
__________________
![]() ![]() North America's first V8 Crossfire 2004 Crossfire with CL500 V8 conversion, Vogtland Springs, Koni shocks, CL600 Calipers/C32 rotors front, S65caliper/SLK55 rotors rear, Ansa Exhaust, HID's, MB SL550 wheels. |
#36 |
I think Kleeman makes headers, but a) their site says it requires cutting and welding, b) they list for like 1200 Euro and c) their application list says for 430 and 500 M113 engines.
__________________
#37 | |
Quote:
I didn't see Kleeman listing anything for the W202 chassis. I just spoke to a fab shop here in Dallas and they would build equal length stainless long tube headers for $2,400 for the first set and the price would drop a bunch after the first set. I have only seen AMS for the C43 and I don't think the gain of that type of header is worth it. Boosted 55's have seen an additional 40 hp with long tube headers. BTW, C43 headers would fit a my V8 Crossfire and of course would also fit a 55 in a C43.
__________________
#38 |
Once again, I suppose we need to ask Money-one which specific headers he has. In this link http://www.mbworld.org/forums/4046712-post208.html he said he acquired Kleeman headers.
__________________
#39 | |
Quote:
You will annhilate V8 RS4's and some stg3 audi S4 V6 TT's. You will scare E90 M3's ,the IS-F and give E39 M5's and modded srt8's a nice challenge or should I say drivers race Kleeman in Colorado claims that they don't sell the C43/CLK headers anymore because of the low demand and age of the car. I have a set on my car. There is a guy with a W208 CLK55 that made his own headers which are ten x's better than the Kleeman headers. He has a mid to low 12 sec N/A CLK55. Look him up in the CLK55 forum I think his handle there is Black CLK. He lives in PA I think. "FOUND and search his threads" http://www.mbworld.org/forums/clk55-...-n-record.html My friend who put the engine in my car mentioned to me that he could easily put the speed shift in my 98 C but why would I want it? ![]() I shift my car on ocasion and she runs beautifully.
__________________
#40 |
The 203 and the 209 are virtually the same vehicle so the pans should be the same. A Clk55 209 came in today and would require the pan swap and whole oil pump swap with possibly the chain. Ran across this when I helped swap a N/A 55 into an SL500 (230). They use a low profile pump and the chain is shorter.
Kleemann headers are virtually the only off the shelf good exhaust you can buy. That is to say if they are still available. Making true long tube headers would be really difficult when getting around the steering box. One would need to convert their drag link assembly to a steering rack first to get the best design. |
#41 |
Drives: 2002 CLK430
If someone were paid for the Kleemann specs, a pair of factory manifolds were used for flange samples, a call was placed to stainless, and a C43 was used for a sample - someone might be able to go into the C43 header business. I'm sure one of the cold weather guys needs a winter project.
#42 |
Location: Switzerland: Locarno (TI), the canton of merlot wine, grappa and fine food
Drives: 98' C240T, 99' C43 AMG "T Rex"
Now that is a great idea...
#43 |
MoneyOne, when swapping an NA S55 engine in, I'm going to need to replace the oil pump and timing chain as well as the pan and pick up? Thanks.
__________________
#44 |
Only applies to the low profile upper pan found on the 209 and possibly 203 55's
#45 | |
Quote:
"Hi Jason, Here are the estimated prices for you; ECU; $1095 + $45 labor + $90 shipping (next day both ways, about 3days downtime as ECU has to go to Kleemann USA in CO) = $1230 Headers, $1495 + $630 in labor = $2125 Cams; $2290 + ~$792 in labor = ~$3082 Supercharger; $8995 + ~$5000 labor/extra parts = ~$14,000 (please keep in mind that an ECU Flash should accompany the s/c kit so if you go with the ECU Flash to begin with, then add the s/c, you’d be looking at a second $1095 ECU Flash charge). LSD; $945 + ~$540 in labor = ~$1485 Please let me know how we can help. Best regards, Jeremy Williams Matrix Integrated Inc. 4000 SW Macadam Ave Portland, OR 97239 503.443.1141 Phone 503.443.1142 Fax 888.249.0013 Orders"
__________________
#46 |
Drives: 98 C43 obs. black\2 tone int
2001 ML 55 motor with 97k for $1500
I have the e55 transmission in my car already and im thinking about this swap more then ever coz this is the best deal I found on this motor so far. Id most likely need valve covers redone and plugs replaced, also rear main seal?? What else should be rebuilt on it before I swap it in? Being an engine out of a ML, what parts need to be replaced on it to make it fit??? Also if anyone can kinda give me a price for all the parts id need, not including labor... I know that the ml and the e55 versions make the most torque which is what im looking for but is that due to different exhaust\intake setups maybe?? Would some of that torque be lost once the engine is in my car?
__________________
#47 |
Drives: haters crazy
Damn that's CHEAP! I will take it if you dont
__________________
Ricer hoopty club president ![]() Run your car not your mouth |
#48 |
I imagine the different torque and power specs for the various 55 motors comes not just from variations in the intake and exhaust setups, but also ECU tuning and marketing. IMO, other than the physical differences that have been documented in this thread, I don't think it will matter which one of the motors from the other cars is installed into your C43.
__________________
#49 | |
Quote:
Btw im gona go look at a motor out of a 2000 E55 tomorrow. They have two here locally
__________________
#50 |
Drives: C43 AMG 5.5 - 396.4HP
I replaced mine with a 5.4 W209 engine. In this case it is necessary to use the original C43 oil pan and oil pump (same for other new models like W203, W171). If you take a W208/210 engine, you can take it as it is.
I also needed to use my old wiring loom, because connectors were diffrent (probably W208/210 will be equal to C43). I had to take the throttle flap from C43 and to mount the knocking sensors you need to dismount the air intake bridge (need 2x gasket). The new engine was also fitted with the secondary air mixing (pump + valves). Fortunately even the old engine didn't have this option, the connectors were present. But unfortunately connectors ere different, so I needed to find the correct connectors. Another big job for me was to change the engine from right hand driven (starter on the left) to left hand driven (starter on the right) and the heating system connection at the cylinder head was closed because the engine was never used inside a car. You can keep control unit for engine and transmission but they needed to be reprogrammed. It is difficult to find one who knows what he is doing in electronics. You can also keep the rear differential gear. For me it is not necessary to drive 300 and more, I am more interested in acceleratioon... With sport air filters and sport catalyst I measured 396,4 HP. |
| Tags |
| c43, c4355, clk430, cover, difference, differential, e55, efi, m113, ml55, mount, rear, swap, turbo, upper, valve |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
