Sign in using an external account
| C36 AMG, C43 AMG (W202) Discuss the C36 and C43 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#101 | ||
Location: Switzerland: Locarno (TI), the canton of merlot wine, grappa and fine food
Drives: 98' C240T, 99' C43 AMG "T Rex"
__________________
AMG OCI Member #4 Preparing for the spring wake-up C43 Euro suspensions specifications Swiss Ultima Can-Am build |
#102 |
Drives: 1 out of 1125 C43's imported to U.S.A
Yes the kit comes with the gaskets and they are OEM gaskets as well. The brown piece is the phenolic spacer.
__________________
#103 |
Drives: 99 c43 / 99 ml430
i really appreciate the mod + dyno service you are providing.. thanks for doing it this way it really adds some nice data to the mix. Hope those headers and spacers give a nice boost.
#104 | |
Quote:
I am not expecting much from the phenolic spacers but the headers, X pipe, high flow cats and ECU tune should really add some scoot
__________________
#105 |
UPDATE:
This is the 2nd day I have missed Fedex with my Kleemann headers. They are going to try again tomorrow and I will be here for SURE. I will post pics once I receive them
__________________
#106 |
UPDATE:
KLEEMANN HEADERS HAVE ARRIVED!!! ![]() ![]() ![]() ![]() ![]() Now I have to have the short piece extended and then send them out to be coated before they are installed.
__________________
#107 |
Drives: 2002 CLK430
uh oh . . . . . you do know the road you're on has no u-turns, right? This particular mod is going to make a difference. A difference you should feel because the engine will actually breathe. It's not like the first time you go wide open on a zx10, sit in GOOD SEATS at a Laker game, or fly in a private jet, but still, it's a noticible difference and I doubt you're going back.
Your next PM could be "Yo, uh, ProjectC55, exactly whats needed for that 55 swap . . . . cause, you know, I need another real hit." Speaking of 55, Vince might be figuring out the problem isn't the 55 at some point today.
#108 |
UPDATE:
The phenolic spacers are being installed as we speak, I will post results once they are fully installed
__________________
#109 |
UPDATE:
Phenolic spacers have been installed, It feels like I lost some torque down low around 2000 RPM or lower but it feels like I picked some up above 3000 RPM as it really kicks around 3000RPM-3500RPM and it just keeps pulling to red line. I am going to schedule a dyno run for the week after next. I will post the dyno results once I have them Next up: Kleemann headers, X pipe, 300 cell high flow Metal'Cats
__________________
#110 | |
Drives: MB C43 AMG 1999
Quote:
looks like your c43 is being a guinea pig when you test certain performance parts on your car. do you ask the seller about pro/cons when you buy all these part? what does he tell you, do you gain any power and better performance? it ain't fun getting ripped off wasting money on junk! ![]() good luck bud. |
#111 | |
Quote:
__________________
#112 |
well its all heresy since who knows the last time his butt dyno was calibrated.
#113 | |
Quote:
Another thing I forgot to mention was that my intake manifold was luke warm after driving for about 40 minutes doing several high speed pulls where before my manifold burned my hand after 30 minutes of normal driving.
__________________
#114 |
If that is really the case, guess that could be a nice and not too expensive upgrade
__________________
#115 |
Drives: 1999 Silver C43
Can't wait for the headers man!
__________________
1999 Brilliant Silver C43 AMG
#116 |
__________________
#117 |
UPDATE:
Headers are going in for modification tomorrow and then sent out to be swain coated. I will post pics after the modifications and after I receive them back from being coated. My exhaust guy said he could make a custom X pipe for me, I might go this route instead of the magnaflow X pipe. Talking with my exhaust guy he expressed some concern regarding extending the O2 sensors. He said extending them may change the resistance and in turn throw a CEL, can anyone clarify this for me??
__________________
#118 | |
Quote:
__________________
#119 | |
Drives: 500hp+ IS300
Quote:
You should just eliminate the cats all together, especially when you are doing little mods like intake manifold spacers and such. If your trying to squeeze every last HP you can out of the C43 (aren't we all), then just eliminate the cats, definitely a few horses to be had there. If your state does emissions testing, you will still pass because there won't be a CEL since you are fooling the O2 sensors. When they smog OBD-II cars, they just plug them into a computer and pull the CEL codes if any (which there won't be). They don't physically sniff the exhaust like they do with OBD-I cars. EDIT: I misread your post, I didn't know he was going to be extending the wiring for the O2 sensor, I thought the concern was sensor placement in the exhaust stream. The wiring on my downstream O2 sensor was all eroded away down to bare wires, so I had to cut the wires at the plug and at the sensor and soldered in new wire, I also had to extend it a little when I had my cats deleted and new O2 bungs welded in. I didn't have a problem. I doubt you will either as long as he isn't adding 5 feet of wire to the sensor Ha! Last edited by yamadjs08; 11-08-2011 at 01:37 PM. |
#120 |
Drives: 2005 CLK55 Coupe
It's possible but unlikely. If it ends up being a problem have it be part of your tune to get rid of the code.
That is how I run no primaries with no codes.
__________________
2005 Mercedes-Benz Brilliant Silver CLK55 AMG Coupe [Eurocharged V4 Tune] [Kleemann Headers] [Renntech CF airbox] [Twin AFE's] Best ET - 12.98 | Best MPH - 108.3 "1 of 247" 2001 Mercedes-Benz Brilliant Silver ML55 AMG [AFE Pro-Dry S] [Only 43K Miles] "1 of 1105"{SOLD} 2001 Mercedes-Benz Brilliant Silver CLK55 AMG Coupe [Twin K&N's] [LET Tune] 13.52@105.90 - 311whp/360wtq "1 of 1343"{SOLD} |
#121 |
UPDATE:
After talking with my exhaust guy we decided it would be best to modify the headers on the car so we can be sure that everything is done properly before we send them out to be swain coated. I have scheduled to drop my car off on Tuesday of next week and pick it up on Wednesday. The headers should take about 2 weeks to get coated and come back and then another day installing them with the rest of the exhaust. I should have the exhaust completed by the first week of December.
__________________
#122 |
watch as soon as you get the car working there will be some freak snow storm in portland
#123 | |
Quote:
No snow this year please, I would like to enjoy my C43 and it's new found power...
__________________
#124 | |
Drives: 2001 E430
Quote:
As for extending the o2's I was having intermittent CEL's after extending them. I sent the ECU to Kleemann and Cory turned them off permanently. He was kind enough to do this for just the cost of shipping. I've since passed emissions testing with no issues.
__________________
Mods•Swain coated Kleemann headers•Metal'cats•Evosport underdrive pulleys•355/328 Brembo BBK•19" Carlsson 1/6 wheels•Carlsson pedals•"Carlsoon" shift **** & lighted sills•burlwood steering wheel & door pulls•H&R cupkit•speedybenz•LED tails•Sprintbooster•Sirius•OEM xenon swap Countermeasures•Hidden Valentine1 with custom mirror display•Laser Interceptor•Laserveil Awaiting install•Stiegemeier ported HPS gen1 SC•SLR cams•Coolingmist•Wald EX bodykit•Phenolic spacers•Eisenmann race•Quaife |
#125 | |
Here is a cut out from a conversation I had with Cory:
Quote:
__________________
Eric 98 C43 + Other toys
| Tags |
| 1999, 300zx, 675, amg, c320, c36, c43, dyno, ecu, eurocharged, evosport, gains, horn, hp, mercedes, pulleys, results, sport, tq, work |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
