Chaninging oil and tranny fluid...
Old 02-16-2012, 09:55 PM
JohnnyRock's Avatar
1998 C43 AMG
Hey guys, gonna be doing some maintenance on the old gal here soon, fresh engine oil and transmission fluid change. Need to know how much oil the 4.3L motor takes as wells as tranny fluid amount? Car currently has 118k on the odometer.
Since the tranny is sealed, isn't there a special part I need to get to add tranny fluid? Sorry, I'm too lazy to search right now....I'll be doing the suspension soon as well.
Old 02-17-2012, 03:43 AM
DRBC43AMG's Avatar
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I recommend you get the tranny flush done by a specialist. You have to change the filter (inside) too. Sometimes you will be faced with some sump studs snapping, so you need to know how to repair this kind of problem. Not for the simple DIY mechanic.
Some info here for different car but similar transmission: http://www.benzworld.org/forums/w210...ssion-faq.html
Old 02-17-2012, 07:02 AM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Also prefered if you can clean the Engine with "Würth cleaner", before changing the oil,, its fantastic product.......
http://www.wurth.co.uk/product-0893558.php
ZAYED,,
Old 02-17-2012, 01:29 PM
JohnnyRock's Avatar
1998 C43 AMG
ZAYED,,
Zayed, with this many miles and time on the clock, this was definitely on my list as well. I had planned on using Lubro Moly product, which I've used before with good results, quality product.
Old 02-17-2012, 01:34 PM
JohnnyRock's Avatar
1998 C43 AMG
DRBC, thank you for pointing this out. A trusted local mechanic told me his machine would actually completely flush the system and the new fluid would make sure to completely clean the inside as its pressurized.
Makes me think I should let the pro's handle this one. So, if I do, he's open to me providing the products. He told me he would use all OEM stuff, but being new to the area, I'm not sure how long it would take to get OEM/better quality product.
What should I add for the tranny flush job? Filter kit? That electrical sensor thingy? (I'll have to find the post which mentions it)
Also, how much oil should I allocate for the oil change?
Old 02-17-2012, 01:45 PM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I recommend that you leave your transmission, to someone that knows what he's doing. Like a independant MB shop, the engine oil you can do yourself. The issue with the tranny is, that is need to replace the right amount of fluid as the transmission has pumps and everything operates on pressures. Too little pressure and nothing works. besides from putting in the right formulated tranny fluid is crucial, and the wrong fluid could start eating away your seals, and might be too progressive for your friction discs. Besides you should also change your trans filter too.
Old 02-17-2012, 07:16 PM
cm60k's Avatar
Sure,, Lubro or Liqui Moly is great choice also.......
ZAYED,,
Old 02-18-2012, 03:47 AM
DRBC43AMG's Avatar
Filter change is mandatory when doing the tranny flush. Check also the plastic plug (very cheap) on the side for any leaks or damage. If oil leaks it will wick up the harness and flood your TCU and then you have a mega buck problem
Old 02-18-2012, 05:52 AM
cm60k's Avatar
Agreeeeeeeed......
ZAYED,,
Old 02-18-2012, 01:31 PM
Outlawlatemodel's Avatar
2006 c230
the whole deal is just like changing the filter and fluid in a chevy turbo 350, pull pan, pull filter, snap in new filter new gasket fill fluid, at the bottom of the bell housing is a whole turn motor until you see a plug, drain torq converter, done, seriosly takes longer to change plugs, get the plug for the wires, but gotta get the car up a bit to reach it, ask the dealer it like 8.5 quarts, pretty simple job. If you have changed brakes, water pump, kinda stuff you can do it
Old 05-24-2012, 03:51 PM
illmaticnyc's Avatar
1999 C43 AMG
i hear from one dealership it is 19 qts...another 9-12 quarts for the transmission fluid...anyone know how many quarts it is when you train the TC as well?
thanks!
Old 05-25-2012, 03:20 AM
DRBC43AMG's Avatar
As mentioned by others, get the transmission service (ATF flush and filter change) done by someone who knows how to do it correctely. This is VERY important for the vehicle and for your peace of mind. The transmission is/was the only weak point in an otherwise bulletproof car.
Old 09-27-2013, 11:18 PM
KJI3jflarryfe93's Avatar
check your Pm
Old 11-07-2016, 03:09 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
my indie doesn't know how much fluid to order for a transmission flush. anyone know?
Old 11-07-2016, 05:09 PM
visal911's Avatar
05 E55 AMG
I just got the transmission service done on my C43. It really isn't a hard job if you have access to a hoist.
Make sure you have a Torque Wrench and buy about 8 quarts of fluid. You must keep the working area surgically clean.
My 99 C43 did not have a torque convertor drain plug, so we drained the pan, changed the filter and we are doing another drain and fill in about 5000kms. We took about 4.5L of oil fluid from the pan/old filter.
Good luck!
Quick Reply: Chaninging oil and tranny fluid...
