Interesting twist to selling my car... (parting C36)
1995 C36 AMG, 1998 C43 AMG
Do you have the plastic headlight covers that are on the inside of the assembly (the ones you take off to change the bulbs)? I'm assuming you didn't drill into them for HIDs. I'm looking for a set so I can revert to stock halogens if need be.
Part # (in case pre/post-facelift models are different): 1305219079
Pics of parts
Can be seen at http://razzi.me/a/10587
So far:
Brushed Aluminum trim is gone
License pate holder is gone
High stop light is gone
facelift climate control is gone
AMG pedals are gone
Amber corner lights are gone
Clear corners are gone
Everything else is good though!
So far:
AMG pedals are gone
1995 C36 AMG
Does your back seat (the bottom portion) have any tears in it? Also, Do you have the driver-side side-view mirror with working spring mechanism?
Much Thanks.
Much Thanks.
#32
My back seat doesn't have any tears in it. If I remember right, it might have a white streak of some kind, but no tears.
And yeah I definitely do.
Also let me know when you're in town again if you want to check out the C43 sometime
#33
1995 C36 AMG
Whatsup,
Are you busy right now? There are some parts that I need for my car and I would definitely be able to meet up today.
I go back to school today, but right after final exams would work for me too. I just have some miscellaneous plastic objects that keep breaking so I wouldn't mind purchasing them off of you.
#35
1998 C43, 2017 Honda Accord Sport
Your interior is the gray, right? I'm looking for a few sunroof-related pieces.
Thanks.
- Is your sunshade in good condition? (no stains, tears, glue is good). I'm looking to get another shade as mine has a few imperfections (I'm picky ).
- Also, you think you can get those rubber accordion pieces out too without breaking the small little connector pieces?
- The front, plastic rail attached to the sunroof glass
Thanks.
#36
#37
Thanks.
Thanks.
#38
It is. I actually had it reupholstered last summer and never did get it back in the car. It's not the original material, so it's not exactly the same, but obviously it is in perfect condition. Unfortunately the metal/plastic connectors are broken. They seem like they can be JB welded quite easily, but I'm no expert, but I do have the accordions though and they're in good shape. (you are talking about the connectors that clip on to the shade and are attached to the accordions right?) And yeah the front plastic part is in good shape. Have to look at how to get it out though
Also to get that plastic piece out, just pry it off (even pressure on both side; pull straight down). Uneven pressure will cause you to brake a piece of a side.
And yes, those accordion connectors.
What are you asking for these pieces?
#39
Cool. Are those 2 little imprints on the shade (left side) because you grabbed it there and imprinted the foam or what? What clips on the shade are you talking about; the opposite (top) side?
They should be. I don't know what else would cause that and I can't check at the moment, but I'm pretty sure they're just imprints. The clips clip on to the two plastic rails on either side of the shade as seen above, and are physically part off the rail system. I wasn't sure if these were the clips you were talking about. They clip fine to the shade, but have both sheared off on the other ends. I'm not sure if they are connected to the accordions or not.
I think I payed $150 to get it reupholstered last summer, so just PM me an offer.
#40
#41
Oh, you're talking about those clips...I have no idea exactly how they work with the rail system (I still have mine on my shade). I'll get back to you on the shade, but am still interested in the accordion pieces (I'm talking about the connectors on those---nipple-like, iirc) as well as the plastic rail.
#42
Okay. Yeah the plastic rail at the front should be no problem. I have the accordions off and I don't think there is anything wrong with them... Though I don't specifically remember nipple like connectors or anything. I will have access to them this weekend though, so I'll get back to you then.
#43
2010 C300
Never got an answer from you via PM, anyways I was wondering if you have the CD changer and is it working? Can you PM me a price?
Also is the driver airbag/steering wheel intact? Would like a price on them as well, thanks so much.
#46
The muffler has a small crack in it from the accident. You can see pictures of it here http://razzi.me/a/10587 I imagine it can be repaired quite easily. Right now I have the muffler and resonator off like the pictures. If you could PM if you want that whole pipe with the res attached or if you would like me to cut off the muffler, I'll get you a price.
The car is in Chapel Hill, NC, USA
#47
This probably wasn't what you had in mind when you said no rush, but I have finally gotten the two accordion pieces and front plastic trim piece. I also still have the shade available if you're interested.
I imagine those are the nipples you were referring to?
More pics: http://razzi.me/a/10587
#48
#49
In search of W222
Shift knob? Please email me with pics and price to bagelsjustbagels@gmail.com
You'll get a faster response! i want to buy ASAP!
#50
1 Post
95' AMG SeeThreeSix
NEED OEM C36 SPRINGS
I am in dire need of the stock C36 springs. I have eibach lowering springs in and am insanely tired of blown wheel bearings and not a shop in the world can adjust my camber to factory spec even with kmac camber kits installed.
Back to the point my nightmare/problem was that the mother went insane during spring cleaning and has been bulldozing our garage..........now my original springs are missing or according to her they walked off whilst growing legs. I just about shattered my wrist on a variety of fairly solid objects around the house knowing what the dealer will charge me for a full set. Im looking for some sympathy and a sympathetic cost for the full front and rear set of springs shipped to zip 06512.
I may also be interested in the steering wheel if the price is right (box em' all up together!) but that is if the price is right. I got thrown out for doing the blaming on momma regarding the missing springs so I'm in limbo, C36 with blown drivers side wheel bearing, zero OEM springs. Thank god I'm good looking and have an amazing girlfriend
But for the greater good of a fellow C36'er PLEASE help me out! You can reach me on here PM, cell/txt (2o3)5oo-3399, or email bbc3o9@gmail.c0m
Thanks a ton, shoot me some sympathetic prices. Life has thrown me enough curveballs for the month. I hope I don't end up getting hit by lightning anytime soon......................
