Want to rebuild control arms front and rear had some questions!
1 Post
1998 C43 Amg
Hi everyone I want to rebuild my suspension. Im thinking of buying new control arms for the front and rear. I just had some concerns. If im installing new lower control arms for the front do I have to change the upper control arm too? And same for the rear it has the lower control arm then upper rear control arm. Do you guys recommended doing the top arms too? Also for the rear theres a rear support arm I already bought. Then theres a rear tie rode links? Also theres sway bar links are those recommended to change too? I just want to refresh the suspension but want to keep it simple. I already changed the front tie rode.
Front
LCA has the large bushing which goes bad, if you have polybushing you can replace the bad one with poly bush then you're ok with LCA.
If you buy complete LCA go for Lemförder or MB oem part and nothing else.
UCA is not necessary to change these bushings seldom goes bad.
Rear
Buy new rod arms there's 6 of them on each side IIRC?
Frame has 2 bushings in the front and 2 bushings in rear + 2 oval diff bushings.
Hubs have 1 bushing each.
You should get adjustable camber arms if you lower your car.
change transmount bushing if your rear axle gives you clunking sound.
I've so far only done my front suspension, with all arms and bushings, tie rod ends, balljoints, stabilizer bushings replaced, only thing left is shox and lowering springs.
The rest of the parts for rear axle I've already bought and have them collecting dust until I buy complete set of shox then I will do the rear suspension.
14 years of old suspension gives me a sloppy performance ride, I don't like it.
I'm waiting for this day to come when I have the rear suspension tighten.
it will cost you a lot to get all the parts at once, I bought my stuff + Vogtland springs from time to time and now I almost have everything besides my desired Koni's
Changing all rubber will give ya synergi with all suspension renewed.
god speed and happy hunting for parts
Here's a pic of a w124 rear axle it's almost the same for w202, it's got 6 suspension arms on each side + a certain amount of bushings
Rear
1 Post
1998 C43 Amg
Thank you for all the info Kowalski. I already did my shocks and springs. I have the rear camber kit, the Mb arts one. I chose to to the rear first because its cheaper for me. I bougth a rebuild kit for the control arms but then realized its a pain in the butt to take the bushings out. I need special tools that I don't have so to save me the hassale I will just buy new control arms and etc.... I Will do the front control arms later. The only thing I did to the front was change the tie rode and steering damper. I cant wait to have the car freshened up so I can rape it and not worry about breaking something hahaaha
1 Post
1998 C43 Amg
Just to double check that I have everything for the rear. I already have the rear support arms and camber kit. I also need the rear tie rode links and sway bar links? heres where im buying the links and sway links http://www.pelicanparts.com/catalog/...SUSSHK_pg1.htm
Then the sway bar links are on the 2nd page.
Then I need the lower control arms and then the control arm strut arm?
and then upper control arm that connects to the strut arm. Heres the webiste im going to be buying some of the stuff from.http://www.pelicanparts.com/catalog/...SUSSHK_pg1.htm
I know this is probably confusing but I tried my best to have you understand. Is there a suspension diagram I can look on our c43's???
1 Post
1998 C43 Amg
Just to make this simpler. To my understanding if im correct. The suspension for the rear has 2 lower control arms, 2 upper control arms, 2 control arm struts, 2 support arms, 2 camber arms, 2 stabilizer arms, two tie rode links and two sway bar links? Am I missing anything out?
Posted from Mbworld.org App for Android
1 Post
1998 C43 Amg
This is what ya need from Lemförder!
1 Post
1998 C43 Amg
Thanks man for guiding me in the right direction. Do you know a link where I can buy the kit? Or do I just go on the lemforder website?
I would go for 1:OEM MB 2:Lemförder - 3:Febi
Missing link is rear swaybar bushings.
I think I covered all bushings for you for rear axle.
http://www.ebay.de/itm/MAPCO-Stabili...item19d484e736
Link 2 covers rear arm - last one at the bottom -, the big Kahuna
http://www.autohausaz.com/search/pro...@Control%20Arm
http://www.autohausaz.com/search/pro...ential%20Mount
http://www.ebay.de/itm/LEMFORDER-2x-...item19db6a038e
http://www.autohausaz.com/search/pro...0Bushing%20Kit
http://www.ebay.de/itm/Lemforder-Tra...item4844348a0c
http://www.ebay.de/itm/Querlenker-St...item5d306ba574
I would just replace the bushings in the front lower control arms. I just did this last weekend on my car. I work at a MB dealer so I get a little price break, but the bushing kits were only $55 each which is front and rear bushings for each lower arm, so $110 for the whole car.. I'm sure that is cheaper than new control arms. Bit more labor though..
My car only has 74k, but the bushings were SHOT.
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Maybe a good idea to start a "torque setting specs" thread to be completed and then get it stickied....!
1999 MB C43 AMG
lower control arm to frame 120nm
balljoint to steering knuckle 105nm
it's best to torque the control arm bolts with the control arms in the loaded position.
