C43 T0 C55
hey ol' chap.
it's nice to see you here.
does your c55 conversion drive like a beast?
E55 engine works well with your stock ecu, did you do anything to it?
car looks beautiful, rims are hot!
boot spoiler is it drilled into trunk?
the boot spoiler is drilled.
the next thing I want to do is upgrade the brakes. I went to the nurburgring a few weeks ago I had bad break fad but it was lots of fun. I might go for the c32/c55 w203 set up but would really like the bigger amg calipers any advise would be great
hi hope you are well my car runs fine but iam still on stock c43 ecu thinking about a tune.
must have been a blast driving at the ring.
c32 brake kit is the cheapest solution.
this is what i have waiting at home for future install.
others do 6/4 kit, i assume it's costly to get these toys?
bigger calipers will get your car heavier.
are there specialists in UK who re-flash the ecu?
can you link their website?
thanks
[QUOTE=kowalski;5688440]I'm fine, thanx for asking.
thanks
http://www.brooklandshorsepower.co.uk/
ill be using this company when I get round to it for the ecu ive spoke to them on phone they know what they are talking about
thanks
when doing the reflash, do i need to pull out the ecu box?
i don't know any specialist in my country whom works with reflashing ecu's?
these shops who does the reflash ecu's, do they have firmware for c43/e55 ecu's to get correct data updated to our c43 ecu's?
thank you for this link.
iam not sure
00 C200 & 00 C55 & 06 SLK55
*AMG "C43/55":-
2 pots caliper with pads = (7.3kg), Rotor = (10.2kg)
*AMG "CLK55/SLK55":-
6 pots caliper with pads = (6.1kg), Rotor = (11.4kg)
*AMG "63s":-
6 pots caliper with pads = (6.9kg), Rotor = (12.9kg)
*AMG "55sK":-
8 pots caliper with pads = (7.1kg), Rotor = (15.2kg)
ZAYED,,
Some of our C43 brakes weight, compare to other newer AMGs,,
*AMG "C43/55":-
*AMG "63s":-
*AMG "55sK":-
ZAYED,,
*AMG "C43/55":-
*AMG "63s":-
*AMG "55sK":-
ZAYED,,
*AMG "C43/55":-
*AMG "63s":-
*AMG "55sK":-
ZAYED,,
*AMG "C43/55":-
*AMG "63s":-
*AMG "55sK":-
ZAYED,,
you foggot to list the c32/c55 calipers/rotors?
what's their weight?
are they lighter than C43 combo?
I focus about the 6/8 pots, comparing to our C43 brakes,
"C32 & C55", is a good brakes to go, cause i may interesting with 6/8 pots, more than 4-pots.....
ZAYED,,
it's interesting to me about c32/c55 combo as I already bought them long time ago.
I would like to know the weight for caliper/rotors.
if you have the info please share with me.
these are a cheap upgrade without any cutting of dust shields requirered
+1,,
The "C32 & C55" 345x30 Rotor is: (11.8kg)
but im not sure about the Caliper,
my friend got those calipers in his garage, i will tell him to weight them & let you know......
ZAYED,,
ZAYED,,
Hi,
The 2 pieces Rotors from "CLK55/SLK55" 340X30, #: "171 421 01 12" is good choice, but they are Expensive,,
Attachment 262292
you can easily go with an ordinary Rotors from "C30/C32/C55" 345X30, #: "203 421 09 12"......
Attachment 262293
ZAYED,,
Attachment 262292
Attachment 262293
ZAYED,,
11.8kg!!! Although slightly smaller I thought the 334 two piece C43/CLK/E AMG fronts were heavy at 10Kg!
Do you guys have the caliper wieghts also?
thanks for your help man
if those 4 pot calipers weigh approx 5 kg each, that's good,
they are still heavy when holding them in the hand.
approx 300 grams difference between c43 and c55 brake combo
500E Signal Rot
Remapping of the stock C43 ECU will probably cost you HP. A friend of mine did this on his C55 and the remapping was the direct cause of the A/F going from 14:1 to 12:1.
Stock C43 ECU w/C43 tune - max power was 284.72 rwhp and 309.89 torque
Stock C43 ECU w/E55 tune - max power was 280.22 rwhp and 292.50 torque
Save your $400 plus dollars.
Also, the C32 brake setup does clear the OE 17x7.5" AMG front wheels, but it does not clear the OE 18x8" AMG wheels (from the W210 E55). Something to keep in mind, we ran into that problem and it will require the front wheels to be modified for clearance.
c43 caliper/rotor/pad combo is 17.5kg according to Zayed
c32 caliper/rotor/pad combo is 17.2kg
are these numbers correct Zayed?
if yes, then it's 300 grams weight difference
