C43 AC PROBLEMS
mercedes c43
C43 AC PROBLEMS
C43 OWNERS, I HAVE A PROBLEM WITH MY AC. I HAVE NO COLD AIR, DON'T KNOW WHY. HERE IS WHAT I NOTICED, THE COMPRESSOR MOTER IS WORKING AND THE FAN IS TURNING. BUT I'M NOT GETTING COLD AIR. ANY HELP IS GREATLY APPRECIATED.
Good luck.
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Most AC systems need a recharge from time to time, generally every couple of years. With my 2 MB's, they both needed recharging after 3 years and they get used most of the year (full auto except in winter and even then sometimes on) to reduce humidity when it gets high.
mercedes c43
TROUBLE SHOOTING AC PROBLEMS, SWITCHED OUT THE TEMPERATURE SENSOR, STILL NO COLD AIR. I NOTICED THAT THE 2 FANS WERE NOT ENGAGING. I HAVE COME TO THE CONCLUSION IT'S TIME TO TAKE IT TO REPAIR SHOP. STARTING TO GET HOT IN TEXAS.
yeah it needs proper diagnosing. is the ec light on or off? is the compressor running? if so, is the low side line cold? if the line is cold but no cold air, then you check the flap system and it could be a vacuum supply problem etc etc etc.
needs diagnosing by someone who knows the car.
Ouch that is $800 labor. Part is $200 plus a few seals that I am sure only cost a few bucks. Find a reputable MB indie specialist, it would save you a lot in the long run for when this stuff happens. The price we will pay for cold air, I get it. Glad to hear it's fixed.
I'm sure there is alot more replaced. At least the receiver drier, new refrigerant and oil, possibly some lines with it, I doubt the mb compressor was only $200 also. Plus diagnosis, plus labor. If it was such a ripoff why did you agree to it?
mercedes c43
To benzslo, I agreed to the service because, I appreciate my car and want to take care of it. I knew parts were going to be expensive. The part with diagnosis, relay switch plus refrigerant where 500.00 plus another 450.00 labor. Just like all Mercedes Benz owners, it's the price you pay for a slice of heaven.
1 Post
C43 AMG 5.5 - 396.4HP
just for information...
If there is a leaquage inside the A/C System, it is running out of refrigerant and the compressor does not start anymore. So this could not have been the problem here. If you follow advise of post #2, in most cases it is possible to detect the problem source.
