Poly bushings
Old 04-19-2014, 01:09 AM
88260EEE's Avatar
1998 C43, 05 Mini Cooper s
Poly bushings
What are the pros and cons to going with poly LCA bushings and sway bar bushings
Old 04-19-2014, 08:15 AM
DRBC43AMG's Avatar
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
No major problems except some possible squeaking...
Old 04-19-2014, 02:01 PM
PJmak's Avatar
Honestly for me the ride comfort decreased noticeably
Old 04-19-2014, 10:35 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
Lot more road vibration transmsitted to the driver. All manufacturers use rubber for a reason, even black series cars, sls, slr use rubber. Poly will transmit alot of unnecessary harshness and will make noise.
Old 04-19-2014, 11:12 PM
88260EEE's Avatar
Ya, think I'll keep it stock
Old 04-20-2014, 12:20 AM
Super B's Avatar
'97 c36
I built up a 1995 firebird trans am and did a full suspension with poly bushings including transmission mounted traction bar. With the 275 tires all around there was so much increased road noise it was uncomfortable to ride in for any long trips.
Old 04-23-2014, 01:44 AM
jnolte's Avatar
744 C36 AMG,040 C43 AMG, CLK55 208, CLS55 IWC, CLK500 Rocketbunny widebody
i have them they squeak on speed bumps but way stronger
Old 04-23-2014, 02:33 AM
cassielily's Avatar
RX-7
In automotive suspension, an automobile's control arm or wishbone (aka. A-arm or A-frame) is a nearly flat and roughly triangular suspension member (or sub-frame), that pivots in two places. The base of the triangle attaches at the frame and pivots on a bushing. The narrow end attaches to the steering knuckle and pivots on a http://en.wikipedia.org/wiki/Ball_joint. A control arm differs from a http://en.wikipedia.org/wiki/Suspension_link because it can control two http://en.wikipedia.org/wiki/Degrees_of_freedom_%28mechanics%29 by itself.
Old 04-23-2014, 09:35 AM
KJI3jflarryfe93's Avatar
do you have the K-mac bushings or LPD bushings?
LPD bushes do they squeek?
I have these but did not install them on my car
do you prevent squeeks with rich applied greasing paste?
Quick Reply: Poly bushings
