Anybody knows what part # is this grey connector?
That is the vacuum plug part# 202 805 0244. It is also found under the seats as it connects the plastic air hoses that allow air into the lumbar and bolster pockets.
00 C200 & 00 C55 & 06 SLK55
The reason i ask, if it only connector, can joined it with rubber hose, no need to stick with it, as one of the hard connector can touch or deal with..!!
ZAYED,,
ZAYED,,
Thanks. I was able to order both the male and female connectors so i would just cut the hose and save myself trouble taking off the old connectors.
By the way, the picture I posted, is that for the AC VENT?
The parts came but the color of the connectors are black. I was able to remove the broken male connector and also cut the end of the hose where the connector broke. However, I was having a hard time putting the new connector in. I think a heat gun would do the trick. Anyway, I ended up using a regular rubber vacuum hose to connect the connector and the white plastic tubing. I should have just used a rubber vacuum hose in the first place and saved myself 9.00 bucks
