Air Intake Temperature Sensor and Wiring
Any help re: the Air Intake Temp Sensor would be appreciated. I have to replace the sensor itself because one of the clips have broken off, its the 2 pin connector. The Wiring Harness is going bad too. Is replacing the entire harness the way to go? Please look at image supplied.
Yes, thanks. When I look closer I see that the wire which is part of the Engine Harness is in bad shape. Probably same for entire Harness. Considering replacing the Harness.
00 C200 & 00 C55 & 06 SLK55
You can get this sensor from dealer or any local MB parts,
MB part #: "006 153 80 28"
Harness is another thing, you can only fix the air temp. harness only, by cutting & soldering, no need to get complete harness for just one wiring circuit damage..!
ZAYED,,
ZAYED,,
