C36 AMG 107 Dwell angle control at stop of ignition output stage.
Hi guys, I plugged my car into the Star due to slight running issue. Slight missfire.
I got error code 107 Dwell angle control at stop of ignition output stage.
Could the ECU cause this fault, It had a new ECU in 2007 but that was before I changed the throttle body due to bad wire harness and voltage regulator.
My friend says it could be a stretched timing chain causing the running issue,
Do you guy have any ideas on a 95 C36 With the 107 Dwell angle control at stop of ignition output stage. Code.
Cheers.
Cheers.
'97 c36
Hey man wish I could help you more but never dealt with that one on the 36 yet. Hopefully some of the other guys will chime in. I did find this link for you.
http://www.club202.com/forums/showth...Need-Some-Help
Give you a couple things to look at.
