Climate control vacuum actuator question.
'97 c36
After testing all the fittings on the vacuum distribution/control box leading to the vac actuators two of them tested bad. Lines are good but diaphragms are bad.
Anyways I was able swap the one pretty easy but how about the actuator that controls the cabin air recycling flap? Does a guy need to pull the crash pad/dash to remove it?
'97 c36
Thanks my friend.. Kinda looked that way but wanted to be sure before putting that kind of effort in. Anything else on the list while the dash/crash pad is off? Half temped to swap all the vac actuators.
2014 ML350 4Matic
I can't think of anything other than looking carefully at everything looking for broken plastic, etc. I have never had to replace an actuator for a diaphragm problem. The problem I had was the return spring for that flap/actuator broke.
