oil pan reseal
oil pan reseal
Any tips for someone who hasnt done this before.
Im doing my oil change this weekend and my oil pan needs to be resealed as well.
I havent done this before so i wanted to see if someone can give me some dos and donts.
How much do i torque the screws, best cleaning methods and stuff like that...
2014 ML350 4Matic
It is pretty simple. The sealant residue is minimal. Don't use a scraper or a knife. Use silicone sealant remover if you can find it. Permatex used to market it but it seems scarce lately. Careful use of a scuff pad is an alternative. Use the M-B silicone. Apply it exactly as shown in the attachment. There is nothing to be gained from applying a lot of torque.
One caution - I have chased leaks on this engine and none came from the pan, even though I thought it did. I pulled and resealed the pan twice with no improvement. Clean the entire front seal area, pan, oil cooler and test port areas and make absolutely certain it is the pan. Leaks from the front seal can appear to be the pan leaking.
SCN_0035.pdf
SCN_0035.pdf
2004 Honda s2000 & 1999 MB c43 AMG
Thanks vinceC for the help. I guess I'll just let it continue to seep. If I need to take the engine out to just reseal it, I my as well drop in a e55 engine in it haha.
Thanks for input guys. I wasnt able to tackle this since its been very hot this weekend.
My oil pan leaks on the very bottom smaller section which has the drain plug on it. I dont think the engine needs to come out in order to reseal that section does it?
You should be fine with the smaller one cause it doesnt look like there anything blocking it. In my case, my larger one is leaking
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Anything related to transmission needs to be surgical clean. Doing work outside may not be the ideal thing with blowing dust etc. Just my 2c's....
You can also take some time to view these instructive videos
https://mbworld.org/forums/c36-amg-c...ml#post6401349
2014 ML350 4Matic
As mentioned earlier, Follow the bead spec and location religiously.. You will notice the lower part downwards face has a few small round recess's and the upward face does not, if you apply the sealant to the upwards face which I assume most people do, than be carful it doesn't alighn with any of the recess's otherwise it will leak
with MB 50ml canister you really need matching MB corking gun.
Does anyone have the instructions on the order in which the bolts have to go back in. I heard you cant just randomly throw them back up, they habe to be tightened in a certain order
Yes sure can be done with regular corking gun just not as easily,I realized how much better the real deal is after trying it,i'd never go back.
As said there is no tightening sequence just do all up finger tight first then torque to spec. Also,try hard to avoid accidently letting the sealant separate once contact has been made, can be a bit tricky with one hand on the pan and the other trying to find bolt holes
