weird problem with key
So my key has stopped working completely.
I am not able to lock the car or turn the ignition. Whats weird is that even the metal key wont lock the car using the drivers door lock.
The batteries were recently replaced but I tried different batteries just to be sure.
Ive had a problem with my vacuum on my car that Ive been lazy to fix even tho I had the part. Despite this my key always worked.
The vacuum problem was that all doors would unlock except the drivers door so I had to reach from the back door and open it. I am not sure if this would be related to this but thought id mention it in case someone has experience.
My car fires up no problem with my valet key. Any ideas?
you have more and more issues with your car.
maybe time to get rid of her and get another c43 which hopefully will be in better condition?
what ya think about getting another car with less headache?
Thanks for the input guys.
Im happy with my car overall and i dont think id want to replace her
I am looking into getting a parts car soon. (Friend has a 98 c43 with under 70k that he doesnt wanna fix)
Btw the red light does blink on the key
Unfortunately, the smart key can go bad overnight and simply it just won't work anymore.
Many cars of mine had the same problem and quick solution is replacement from dealer. I just ordered a new key 2 days ago for $260.
The blade will central lock/unlock the car only from the trunk. Using the blade at the drivers door will lock/unlock only the driver door.
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Perhaps a bit OT but still key related....
Some time back when I cleaned out the rear of "T-Rex", I found a complete key fob under the heat/sound insulation of the rear seat. OK the battery was dead, but with a new one installed the key works perfectly giving me three to use and swap around from time to time.
00 C200 & 00 C55 & 06 SLK55
You may have a bad "OCP/MHz" receiver, it's one of important part of key fob system.!!,,
see our fine friend Paul thread:-
https://mbworld.org/forums/c36-amg-c...rf-pickup.html
ZAYED,,
ZAYED,,
It's your key. From what I understand, you can only get them at the dealer. Call around, they can be had for as little as $200. Don't buy keys off eBay, they will not be programmed at the dealer.
