The Part number for a intake manifold
mercedes c220 c36
Is there anyone knows the part number for a intake manifold for a C36 amg -96
I managed to destroy the to pipe intake for some kind of air pipe on the undeside of the manifold. I'd tried to glue them back but i'm not sure if it work like 100% because the car runs like **** on the idle.
mercedes c220 c36
Do you know anything about the Crossovertube if you really need the fat one that have the text 3.6 on it? or can i use the crossovertube from and older c36 wich is not as fat and doesn't have the 3.6 text in it?
mercedes c220 c36
I have problem finding the intake manifold with the partnumber you gave me. I rather find a used one.
if you check this link:
https://www.bildelsbasen.se/?link=it...st_id=24400052
There is also a intake manifold from a c 36 amg 97 with the same engine number 104.941
Do you think it will fit my car?
Do you know whay the things on the underside of the manifold where you attach the rubber tubes on and if they can be the cause of my engine running very badly on idle when the engine is hot
00 C200 & 00 C55 & 06 SLK55
Yeah, this is the correct one, they write the part# provided above as well..!
many things could cause poor idle "bad CPS/bad MAF/bad plugs & coils/bad or clogged fuel filter",
prefer to diagnose the car first, codes will help to narrow the issue..!!
ZAYED,,
ZAYED,,
mercedes c220 c36
Ok but it's start when the engine getting warm
So it will work with the one in the link that i posted?
If you check this site
https://www.flickr.com/photos/jumph4...7623222462932/
and scrolled down to the pictures to the right of the intake picture you'll see the the two holes closest to the part that is attached to to the head and thoose are for some kind of vacuum tubes. could thoose have anything with the bad idle to do?
It's great site with pics..,
yeah sure, it will work with the one in the link you posted..!
vacuum leaks could cause rough idle, but better to diagnose the car before changing anything..!!
ZAYED,,
ZAYED,,
mercedes c220 c36
Ok. i'm gonna change the intake what so ever because i know it's been damage and i don't want to be unsure if thats the problem.
I'm gonna start with a new thread with the big problems
mercedes c220 c36
But you said some certain number an above will work.What does that mean
if i get a intake with the partnumber 1041403601 which also is for a c280 and look very alike the other two. Will it also work or? and if not how do i know exactly what to look for?. the reason i'm asking is that i'm not gonna by it now and i'm checking both swedish junkyards for parts and also looking on ebay
*if you want cross tube with (3.6) logo, you can go with any following #s:-
"H WA104 141 01 04" or "H WA104 141 02 04" or "H WA104 141 04 04" or "H WA104 141 06 04"
**if you want ordinary cross tube without (3.6) logo, you can go with any following #s:-
"104 141 22 04" or "104 141 27 04" or "104 141 33 04"
ZAYED,,
ZAYED,,
mercedes c220 c36
Attachment 325014
Attachment 325015
ZAYED,,
Attachment 325014
Attachment 325015
ZAYED,,
mercedes c220 c36
Yeah, Black one(see attached),,
you can go with any below #s:-
"104 140 36 01" or "104 140 38 01" or "104 140 40 01" or "104 140 45 01"
Attachment 325016
ZAYED,,
Attachment 325016
ZAYED,,
Thanks alot. Do you know what the diffrence is about them?
All these #s are the same, but MB replace some #s during to different factory production line,
Never mind, don't think about these things, it's a factory reference for marketing purpose..
ZAYED,,
ZAYED,,
mercedes c220 c36
Ok thanks alot. Gonna order one but it will take some time before o could try it.
