ET44?
1999 Mercedes Benz C43
Assuming this (ET44) for Rear Rim, isn't..?, if so, it will be OK..!,,
(ET44) is the off-set of the hub height from inside(where the Rim mounted to the hub)..!!
Attachment 332082
ZAYED,,
Attachment 332082
ZAYED,,
What I didn't tell you but I told the wheel guy, is that I wanted a fifth rim as full-size to use as spare, a spare for all four and that it had to be 35mm offset. this is the second time he sends me an ET44! That's why I have two.
Thanks so much Zayed thank you for clarifying. I guess I was right to think ET and OFFSET are the same meaning and 44 means 44mm
