How to set camshaft timing for c36 amg?
Old 06-26-2016, 10:51 AM
zibpka's Avatar
mercedes c220 c36
I want to reset the camshaft timing for my c36 amg -96 but i'm not sure exactly how to do it.
From what i been told before you are suppossed to put one 4 mm drilbit in a socket on the backside of the exhaust camshaft sprocket in it should be in a horizontal line with the head and it should also be a holes in the intake side and the same procesdure. And then you should have the spike on the engine block on the OI1 crankshaft pulley.
But if you watch this video below this guy doesen't use the OI1 on the pulley. From what i can see he uses the little spike on the crankshaft pulley and put it towards the OI1 on the pulley.
So now to my big question, which is it?
Quick Reply: How to set camshaft timing for c36 amg?
