Engine Wanted
*in Germany; they upgrade their M113 "head/intake/gearbox/headers/ECU remap", on many models, that was in "Nürburgring drift cup",
they called it "evo/SR",
*in Japan; they put M113 Engine assembly from "Slk55 Black series" in W203 C55, on "Japan RC/44 drift",
they called it "CR/M113 SS evo",
that's the only info. i know about "M113/evo",,
if anyone got more info., pls. light it up..!
;ZAYED;
;ZAYED;
1999 C43 AMG, 2005 E55 Wagon
Ni8
Before I were to throw 15 20k into this motor NA Im going SC for less than a fraction of that 20k and have more hp than you could reliably extract from the 5.5l NA. You are not going to do better than the 5.5l SC Motor nor the new DOHC 5.5 l biturbo V8 with the 5.5l normally aspirated. PS try racing the new 2k14 to 2k16 5 .0l mustang GT and you will get the surprise of your life topend!!!! My friend has an auto and runs low 12s with drag radials at 118mph. Also the present valve train can deal wth bigger cams and higher rev limiter no problems. These cars are over engineered. Ever ought out why you have a c280 diff connected to your 5.4l v8 and deals ith the 391ft lbs of torque quite well.
I very seriously one day want to go the M113K route but there are so many unanswered questions as to what I need to get it done. Getting the engine to fit is one thing, but how much of the donor car do I need? What about ECU?
You can find crashed 55k cars for around $5k now. Buy the whole car and you have almost everything you need. I just don't want to pull the trigger until I know what needs to be done. The original 55 swap was painless and took less than a day and I had my car back.
Do i need engine, transmission, EIS, ecu? These swaps are happening now but I need to know what all is required!
edit: are you saying you got smoked by a stock 5.0 in the topend? or you were able to compete with him? honestly neither would shock me.
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Fitting a 55k is not a major problem and has been done in the past. The BIG problem is getting the electronics to talk together in the same language... That also has been done but at what expense
#32
I agree 100%. i'm not going to go crazy on my 5.4 motor, just keep it as is.
Id much rather have a naturally aspirated even 400hp v8 in my 202 over the supercharged m113k
