Deadrest pedal
Deadrest pedal
Do you have any of these pedals fitted on your car?
Does plate fit perfectly?
Does plate sit properly attached with adhesive tape or velcro on carpet?
Rubber knobs on SS plate, are they the same size like factory rubber knobs on the other pedals?
Rubber quality is it long life or do they wear down fast?
http://www.ebay.com/itm/Stainless-St...BUxrXT&vxp=mtr
http://www.ebay.com/itm/Front-Left-F...5YNszE&vxp=mtr
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
2014 ML350 4Matic
I modified a dead pedal from a MK IV Golf to fit and attached it with velcro. Nothing fancy, just a plastic footrest, but it covers the carpet. It takes a bit of work and you have to make a pattern.
http://www.ebay.com/itm/Mercedes-Foo...SZB3LQ&vxp=mtr
haha. ok what about http://www.ebay.com/itm/Aluminum-Alloy-Footrest-Brake-Pedal-For-MERCEDES-BENZ-AMG-W120-W124-W140-W202/271917828167?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D38530%26meid%3Dfe2a50c5749343a99e374caffdf00e20%26pid%3D100005%26rk%3D1%26rkt%3D2%26sd%3D400258671302
kind of the same lol
To avoid mixing things that do not go together, leave the footrest as it is, CARPET!
Wipe your shoes before climbing in.....
I always tap my feet together before swing my legs inside. That way you loosen most dirt off. In worse case, you need to vacuum more often
A wipe and clean with some shampoo from time to time will keep the carpet spotless!
