Gas Filler Access Lock
Old 02-18-2017, 08:45 PM
mkoons's Avatar
1999 C43
Lock on my gas filler door is not working, needed gas today and couldn't get
access. After removing all the interior panels inside the truck I was able to
grab ahold of the lock plunger, but there is so little room I don't know if I can
remove the lock assembly.
Has anyone had experience with replacing this lock ?
Old 02-18-2017, 10:55 PM
PJmak's Avatar
I had that issue. Its basically a small pump.
Mine got me so frustrated at a gas pump that I smashed it and left dents in the gas cap lid.
It eventually opened so what I did was lube it a bit and replace the lid with another matching color one lol. Never had an issue since.
Old 02-18-2017, 11:48 PM
mkoons's Avatar
1999 C43
Thanks PJ for the info, I'll try lubing it, it's a $50 part on ebay but I have no idea how to replace it, there's no room to access the pump.
Old 03-18-2017, 11:59 PM
mickey13's Avatar
1999 AMG C43
stupid question, but how do you lube this? inside, outside?
Old 03-19-2017, 03:15 PM
mkoons's Avatar
1999 C43
It's not an easy job, first i removed the truck interior liner from right side.
There is a very small access hole to reach the pump if you have a small
hand. Put a dab of grease on the end of finger and reach in thru hole and
apply to plunger rod.
Due to limited access I have no idea how you would ever replace the pump.
Anyways, that cured my problem.
Old 02-08-2020, 11:02 PM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
I
Quick Reply: Gas Filler Access Lock
