Help! Turbo Kits,com BOV Spacer install help
Okay-i'm stuck! Ive read the instructions and various write ups. The Bov on the side of the vehicle is hidden under the coolant reservoir. Per instuctions i removed a bunch of screw and moved coolant lines out of way to be able to move the reservoir off to the side. I look underneath and i can barley see the BOV...it seems impossible to even get to it still, let alone see it. Am i missing something???
Thanks in advance!
Thanks in advance!
I only installed the spacer on the one side. I gave up on the other side, just couldn't figure out a way to reach it. I even moved over the fluid housing and still couldn't reach it. It sounds okay-but probably would be much louder if both were done. I'm not sure if its safe to drive with only one spacer on?
Try giving Weistec a call or email. Don't go into specifics of where you bought them, just say that you purchased BOV's through them and need a bit of help. They might have a trick or tip that could help you out.
