C63/C63S AMG
Tune Price for the Record Books !!!
Old 02-10-2017, 04:42 PM
Guilty's Avatar
'16 C63-S
Originally Posted by OrientBlue3
Please PM price!
It's on the ad. $999 !
sales@eurocharged.com (02-10-2017)
Old 02-10-2017, 05:29 PM
AMGTown's Avatar
AMG C63
Wow...! This is a nice deal. I wish the ECU removal process wasn't such a PITA. You guys should look into getting a presence here in SoCal.
Old 02-10-2017, 05:37 PM
SPONSOR
sales@eurocharged.com's Avatar
C63S
Agreed! Why did AMG have to do this to us on the sedan and coupe !? The GTS ecu is accessible without tools
We have worked with Autotalent in the past in SoCal!
Old 02-11-2017, 06:01 AM
Gunsmd's Avatar
2017 Mercedes C63s coupe
ECU tune sale
Have a 2017 C63s coupe with BMC filters. What kind of HP/Torque can I expect from the Tune?
How long is the turnaround time for flashing the ECU? If I ship it overnight on a Monday from Miami when can I expect to receive it back?
THanks
Old 02-11-2017, 01:31 PM
M177ED1's Avatar
C63S EDITION 1
Originally Posted by sales@eurocharged.com
Before going into the dealer send it back to be reflashed to stock.
just to be sure, this still requires a removal (drop of the transmission) of the ECU correct?
Also, are there any EUroCharge in Northern California zip 94534?
Old 02-11-2017, 01:35 PM
skim7x's Avatar
Mercedes-Benz E63s AMG
​​​​​​uhhh no. Would recommend doing more research on your part before you get a tune. Transmission drop is for the downpipes.
Old 02-11-2017, 04:53 PM
  #32
Guilty's Avatar
'16 C63-S
The tranny doesn't need to be dropped to remove the ECU. It's about 3-4 hours of labor to remove it and install it back.
Old 02-13-2017, 08:39 AM
  #33
URG8RB8's Avatar
2015 C63S Edition 1, 2018 BMW M2 6MT, 2016 Volvo XC90 R-Design
THanks
I'd like to know this, too. I'm in Palm Beach County. I'd like to know how much downtime to expect, before I jump on this deal.
Old 02-13-2017, 08:54 AM
  #34
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
If you can get it to us before 11am it goes back to you the same day shipped overnight.
IE Send monday for early am next day service, we get it and tune it tuesday, for return wed.
Old 02-13-2017, 02:21 PM
  #35
jkob5's Avatar
19 E63s
PM me a price including install in Houston.
Old 02-20-2017, 09:35 AM
  #36
SPONSOR
C63S
Tune, Downpipes, Weistec Air Filters !
Old 02-20-2017, 10:15 PM
  #37
Mikeki7's Avatar
CLS63, S55
Any love for the bigger brother M157?
sales@eurocharged.com (02-21-2017)
Old 02-21-2017, 05:06 PM
  #38
M177ED1's Avatar
C63S EDITION 1
EC
How does the ECU reflash work with maintenance? Will the tune be wiped when the dealership does and update?
Old 02-21-2017, 07:07 PM
  #39
SPONSOR
C63S
EC
If the dealer updates the software, then yes, the tune will be wiped.
Old 02-21-2017, 07:55 PM
  #40
AlexZTuned's Avatar
2017 Porsche 911 C4
Can you post or PM me the ECU removal instructions? I have the Coupe so not sure if it differs from the Sedan.
Old 02-21-2017, 08:32 PM
  #41
Dthquazi's Avatar
2017 c63s
Did you find them a couple threads down? In the ECU DIY thread?
Old 02-21-2017, 09:04 PM
  #42
AlexZTuned's Avatar
2017 Porsche 911 C4
Yea, that's for the C43 which sits right on top of the engine bay. The C63S ECU is located somewhere in the depths of hell from what I've heard.
It's times like these I wish we had a separate forum for C63 owners...
Old 02-21-2017, 10:32 PM
  #43
Dthquazi's Avatar
2017 c63s
The way I read post #5 in the thread is that it is for the c63...
Old 02-23-2017, 12:01 PM
  #44
SPONSOR
C63S
This is what was written up a while ago.
1. Remove all three under trays
2. Unscrew the two E10 bolts holding the wiring harnesses to the top ECU bracket
3. Unclip the two coolant lines attached to the front of the ECU lower front bracket
4. Remove the single E10 bolt from the front of the lower front ECU bracket
5. Remove both electrical clips that are plugged into the ECU
6. Slide the ECU forward slightly approximately 1.5”
7. Remove the 4x T30 screws retaining the front and rear lower ECU brackets 8. Remove both brackets from the vehicle
9. Now slide the ECU forward almost into the fan
10. Start to push the ECU to make a 90 degree turn
11. Being careful not to damage the fan or the coolant reservoir while pulling the ECU out of the bottom center of the car
-Tiff
Old 02-28-2017, 01:04 PM
  #45
M177ED1's Avatar
C63S EDITION 1
Can we purchase and use physically use the tune at a later date?
Old 02-28-2017, 01:07 PM
  #46
SPONSOR
C63S
Yes! Definitely. It's at your convenience. (:
Old 02-28-2017, 09:12 PM
  #47
jkob5's Avatar
19 E63s
Dropped the car off today.
Old 03-01-2017, 03:39 PM
  #48
WhiteKnight16's Avatar
2008 BMW M3, 2017 C63s Coupe, 2015 S550, 2018 E63s
Let us know how it goes! I am dropping mine off at the end of March.
Old 03-01-2017, 05:31 PM
  #49
M177ED1's Avatar
C63S EDITION 1
I did some exploring under the car and found the ECU. Unfortunately I am in call so I can't be out of service for even a day.
I dont one know what exactly you guys do when you bench tune the ECU
But after poking around, it looks like there might be room to Unplug the harness and maybe plug an extension into the front of the ECU for a "kinda-sorta handheld tune" from a hand unit or even a laptop then plug the harness back in.
Its not exactly an OBDII plug and play but has that option been explored?
Old 03-01-2017, 05:45 PM
  #50
AlexZTuned's Avatar
2017 Porsche 911 C4
I believe these ECU tunes are still bench flashed only which requires physically opening up the ECU in order to unlock and write it.
Quick Reply: Tune Price for the Record Books !!!
