Wipers chatter like hell
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
My wipers chatter on the 2015 W205 C63S
Turn them on when it's raining and the sputter around chattering and skipping like crazy.
New blades or new wiper arms don't fix it. The dealer isn't helping, doesn't know how, doesn't seem to be getting support on the issue. I tried on other C300 demo in the lot and guess what, same problem.
My friends 2015 C300 does the same and worse, he has been in several times, they want to replace the windshield as the next attempt.
What is going on?
What is going on?
What is going on?
What is going on?
Jeebus, does anything work the way it should on this car?
At this rate, I'm going to wait 4-5 years for the facelifted MY's to roll out.
This kind of stuff should not be happening on a brand new car, first MY or not.
We need to start a "Stuff that should work, but doesn't" thread and keep track of this stuff on a huge lust. Kind of like the W205 guys in other forum section. I will contribute at least 4 things that required service.
This is nuts.
This is nuts.
Same problem here. I've had mine replaced by the dealer two different times with no luck. I finally bought Bosch Icon 22 OE blades and they work perfect now.
There is a thread in the W205 forum on this:
https://mbworld.org/forums/c-class-w...ades-w205.html
Same here on my car. It's like the wiper blades are either super new or super old.
Wiping them clean and adding Rain-X did the trick. But I added Rain-X to the blades and windshield.
Received 1,885 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Had the same problem on last three e-classes ... All 2014 my
Not a specific prob with w205
I'll try the Bosch Icon 22 OE blades. Apparently they can fit the W205 changed wiper arms. Worth a try for $25. I'll look into it.
It's a real **** off for MB to design such a ****ty result and not fix the design error.
No matter how nice the car is, when the wipers chatter like hell and you look at the Hyundai next to you with smooth running wipers, you can't help but shake your head.
I used my for the first time because it finally rained in Vancouver and it also chattered. I sprayed some Windex on the windshield and left it on overnight, no more chatter.
The chatter keeps coming back no matter how you treat the windsheild. At times it takes a few wipws for the chatter to return.
The Bosch aftermarket don't fit.
When will MB find a real fix? The dealer is dumbfounded.
Did you remove the platic connector from the wiper? That's what I had to do and they snapped right in.
There must be different versions of the wiper arm.
The Bosch does not fit on my car.
I noticed that the CLA has the different arm connector and they would fit on that style but not my style.
Meanwhile, they came up with new things such as wiper fluid sprayed from the blades while they couldn't even fix basic blade operation.
The dealer just told me they need to aquire a special tool first to check and adjust the angle of the arm/blade as per an MB service information bulletin.
Well they used the so called windshield wiper special tool on my friends C300 W205 and it did not fix the issue.
They insist using the same tool on my W205 C63S to verify, as they HAVE TO follow procedure on every car complaining about the chatter and I doubt it will yield better results.
MB Canada customer service have heard from me and don't have an answer. They now have a TIPS report in the system.
It's very concerning that MB does not have a solution.
I think it's the quality of the blade rubber or the blade geometry and there is no after market blade that will fit these new arm couplings.
MB has been building cars for 100 years but they screw up the wipers.
'15 C63S
The rubber seems to either be stiff or dirty from the factory.
C220d Avantgarde
When the windshield is almost dry, they chatter. When you payed attention during Physics you know why :-) But they do their job very, very well. Whipping the window dry. Off cause you can have them run smooth, but then the would not whipe that well :-)
I polished the windshield twice with glass wax polish from Griots and applied RainX and Cleaned wipers with RainX twice. with a good amount of rain there is NO chatter but with a light mist there is a small amount of chatter
