C63 AMG (W204) 2008 - 2015
PCMCIA (PC Card) Reader and SD Memory Card Installed w/ Photos
Old 01-05-2010, 02:25 PM
Shellbmb's Avatar
14 GL550; 14 E63s
Originally Posted by gravedgr
The problem with the PCMCIA slot is that if you have most of your songs in iTunes (and they aren't DRM-free), you can't export them in mp3 format. I need an inexpensive (i.e. not the new multimedia crap they want to sell on top of my existing iPod adapter) hookup that lets me browse songs, playlists, etc. all from the COMAND screen.
Is there a converter out there that coverts DRM files from itunes into .mp3 files? Or you can always burn CD-RW discs from Itunes, then rip them back into .mp3. Pain in the butt if you have tons of songs, but it works.
Itunes will also happily take your money to convert all your old songs to DRM free tunes.
Old 01-05-2010, 06:15 PM
gravedgr's Avatar
2009 C63 Capri Blue
Originally Posted by superlubricity
1) In 2010+ models the iPod connection/adapter in the glove box allows for everything to be viewed and controlled on screen.
Not helpful with pre-2010 models, or any without the adapter. Or anyone unwilling to pay the awful price to have it added after purchase.
2) I highly-recommend Amazon MP3 as a DRM-free alternative to iTunes downloads.
Not helpful to anyone who already owns DRM-laden music in iTunes (i.e. the majority of the market, if you believe Apple's info).
Yeah, I have 4k or 8k songs in iTunes (I forget). Very frustrating to build something for the market leader that doesn't work (old adapter) then replace it with what people want (new adapter) and charge a f**king arm and leg.
Old 01-17-2010, 05:32 PM
Unbreakable1's Avatar
2009 C63, 2000 Nissan Maxima
sorry to bring this thread up again...having some issues
got the pcmcia card and a 16gb sd card...
the card will read on my laptop when i plug the sd card into the adapter, and i have some music on the card, but when i plug into the car it says "no memory card"...
any ideas? anybody had a situation like that?
thank you!
Old 01-17-2010, 05:49 PM
Super Moderator Alumni
superlubricity's Avatar
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Which adapter and which memory card are you using?
Old 01-17-2010, 06:52 PM
sd card
pcmcia
specs:
Compatible with Window 98SE/Me/2000/XP/MacOS 9 or above
Card Support: SDHC, SD, xD, MMC, HS MMC, DV-RS-MMC, MS, MS-Pro, HS MS Pro, MS-MG, and many flash memory cards.
Supports 32-bit CardBus Slot
Old 01-17-2010, 07:01 PM
Can't help you there. I've heard stories of others having problems with certain brand adapters/cards. I chose the combo in the first post because of a previous user's positive experience.
sd card
pcmcia
specs:
Old 01-17-2010, 07:07 PM
  #32
JonMBZ's Avatar
06 C55, 09 E350
Two things, even though they really don't help your situation.
Itunes has been DRM free for about a year now.
Old 01-17-2010, 07:44 PM
  #33
ive also tried a few other sd cards and none of them were read...im willing to bite the bullet and try the card you have i suppose...i can juss leave this adapter card in my laptop...
i juss dont wanna be left w/ 2 cards that dont work...or juss stick w/ the ipod...damn
Old 01-17-2010, 07:48 PM
  #34
Below is where I bought mine. The picture in the listing didn't match what I got but it worked perfectly.
eBay Seller: adapterbest
Shipped from Hong Kong
Item Title: PCMCIA Card Reader Adapter for SM/SDHC/SD/MMC/MS/MS Pro
Old 01-17-2010, 07:59 PM
  #35
JonMBZ's Avatar
06 C55, 09 E350
the problem most of you are having is most likely you are getting ones without HC suport. Make sure it supports SDHC because if not you will only be able to use up to 2GB SD cards.
Old 01-17-2010, 08:03 PM
  #36
it supports sdhc also...plugged into the laptop will read 16gb...i plugged in a few 512 mb cards too, but no luck
Old 01-17-2010, 08:09 PM
  #37
JonMBZ's Avatar
06 C55, 09 E350
Sorry not sure then, I would just try the one he is using if that does not work maybe there is a problem with the PCMCIA slot on your radio
Old 01-17-2010, 08:26 PM
  #38
sjhugh's Avatar
C63 AMG, BMW 135i
I agree, go with what you know is working for others.
As an alternative, my Owner’s Manual does state that not all PCMCIA cards will work. It advises, if in doubt, contact Mercedes-Benz. I’m sure you wouldn’t be the first MB owner to run into this problem, maybe a phone call or e-mail to MBUSA could quickly put you on the right track.
Old 01-18-2010, 12:31 PM
  #39
JonMBZ's Avatar
06 C55, 09 E350
MB supplies one and I am sure that they will just suggest that. I do not think it's HC compatible because they only offer a 2GB SD card with it and its about $100 for the card reader :\
Available with COMMAND only. Supported Memory Cards:
SD, MMC, HS MMC, DV-RS-MMC, C-Flash*, T-Flash*, Mini-SD*, RS-MMC*, MS, MS-Pro, HS-MS-MG-Pro, HS-MS-Pro, MS Select, MS Duo, MS-MG*, MS-MG Pro*, MS-Duo-MG*, MS-Pro Duo, MS ROM*, X-card.
Attached Thumbnails PCMCIA (PC Card) Reader and SD Memory Card Installed w/ Photos-b67823973_sdmemory-20card.jpg
Old 10-19-2016, 06:11 PM
  #40
SuperFastYo's Avatar
C63 AMG - LSD
old old old bump. Anybody know why it wont work for me? Do the songs have to be out of folders?
Old 10-19-2016, 06:25 PM
  #41
bhamg's Avatar
C63 AMG
No, folders are the way to go. Give it a few minutes to load...you can confirm that by accessing the folder menu when it appears and selecting a folder even if music is still loading from that folder. Clumsy and clunky but it's still useful as a media backup...curiously, I've found the same music from an iPod sounds better so media on the card is for emergency use only.
Old 10-19-2016, 07:51 PM
  #42
604 C63's Avatar
2012 E550 Cabrio
Not all card readers will work. I have a Sandisk, and that worked well. These are getting hard to find.
Old 10-19-2016, 08:06 PM
  #43
roadkillrob's Avatar
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
Wow I had no idea they ever put a PCMCIA card slot in a car until I read this! - guess Mercedes went with Betamax and everyone else went with VHS!
Old 10-19-2016, 08:07 PM
  #44
604 C63's Avatar
2012 E550 Cabrio
Yup. Until the facelift I believe.
Old 10-20-2016, 11:08 PM
  #45
C63 AMG - LSD
Can't seem to find one, they're probably no longer in production
Glad my bump helped you find something new! Unfortunately its just another frustrating Merc thing but hey, new is new I guess
Old 10-20-2016, 11:39 PM
  #46
604 C63's Avatar
2012 E550 Cabrio
Well, SuperFastYo.......today is your lucky day. I happen to have one right here.
PM me your address, and I'll pop it in the mail. My gift to you.
All I ask is that you ignore the dirty counter in the picture, and are nice to Canadians
SuperFastYo (10-21-2016)
Old 10-21-2016, 12:02 AM
  #47
C63 AMG - LSD
This guy, this guy is a stand up guy
Old 10-21-2016, 12:25 AM
  #48
604 C63's Avatar
2012 E550 Cabrio
But people tell me I am a little cranky sometimes lol.
Old 10-21-2016, 09:12 AM
  #49
C63 AMG - LSD
Thats gonna follow you on this forum for the rest of your time here haha
Quick Reply: PCMCIA (PC Card) Reader and SD Memory Card Installed w/ Photos
