Sign in using an external account
| C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: MB
BRABUS Door Lock Pin Install Video
#2 |
Drives: 2012 CTS-V
Cool.
Any chance of making similar pins but with an AMG logo on it? |
#3 |
Drives: MB
similar pins
nope. brabus makes them, not sure if AMG will get into that or not. Custom pins might be possible, but will be more than the brabus units, which are $125 plus tax and shipping..
#4 |
Drives: 2012 CTS-V
Not a problem with price for me,
within reason![]() Anything beats the plastic pins that Mercedes installs from the factory. I like the Brabus pins but having an AMG vehicle, I prefer to have AMG pins. Thanks for answering my questions. |
#5 |
Drives: MB
pins
The are in stock, install coming soon. $125 each plus tax and shipping. The rear door pins, on the install, you need to cut the existing lock pin (black mercedes unit) and shape it an press the pin over the modified piece, and install the door panel, height adjustment has to be tweaked. The front screw on..
#6 |
Just to let everybody know that there are already out amg door pins. Just check AMG website. You will find them there on the accessories section.
#7 | |
Drives: MB
Quote:
Yes, your correct I guess AMG heard the call. They are available, special order $170.28 + tax and shipping. For front doors: A000 766 0228 For rear doors: A000 766 0328 Includes all four door pins, front and rear, here is the website for a picture installed. http://www.mercedes-amg.com/#/acc-c-class Once there, on the left at the bottom, click on Door Pin. Last edited by TheWorkshopMB; 01-07-2010 at 06:10 PM. Reason: more information |
#8 |
Drives: '86 190e restoration project, '08 Acura RDX, '09 C63 AMG
Is there a PN for the AMG units?
EDIT: NM. It is on the site.
__________________
"Unofficial Member" of the Vancouver Benz crew. |
#9 |
Drives: 2012 CTS-V
Here are the part numbers for those who do not want
to click on the link. For front doors: A000 766 0228 For rear doors: A000 766 0328 Brushed stainless steel w/AMG logo Nice! ![]() The Brabus pins are very nice too!
__________________
2012 CTS V SEDAN Stage 1 Mods: - 2.5 upper pulley with ported snout/throttlebody - Fluidyne HX - Airaid CAI w/green filter - ID850 injectors - 160 thermostat 12.18 @ 118.98 - STOCK 10.87 @ 127.02 - STAGE 1 Stage 1 Track Video |
#10 |
Drives: '12 C63 Black Series, '12 ML63, '12 CLS63 (Sold), '10 C63 (Sold), '10 VelociRaptor, '09 GL550
I just talked to the most unhelpful MB parts person ever - does anyone know if the PN on the AMG website is for a pair of pins or only one pin?
__________________
#11 |
Drives: Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
It's retarded how the rear pins require cutting and shaving to install, plus you'd have to open the door panel to be able to safely apply downward force pressure without damaging the locking mechanism. Since you're already destroying the original pin to fit the caps over it, should have designed a pin that can be pressure held to the inner pin (the one you see inside after you pull off the original pin). Inner pin already sits perfectly flush when locked. For such a simple mod, definitely not for the feint of heart.
#12 |
Was he/she able to pull up the PN? You could probably figure it out based on the price quoted.
__________________
#13 | |
Quote:
She quoted me $93 and change - should I probably take that as a pair?
__________________
#14 |
Drives: MB
#15 |
Drives: C63
The AMG ones look nice. I'm looking forward to the video, especially for the rears, just to see how much work is actually involved.
#16 |
Drives: 2012 CTS-V
+1
__________________
#17 |
Drives: MB
video
#18 | |
Drives: 2012 CTS-V
Quote:
I am definately interested in a set but I would like to see the video first.
__________________
#19 |
Drives: MB
#20 |
Drives: 08 MB
I hope my install sheds some light for people.
There isn't much an aftermarket company can do with the factory design for a simple install. http://www.mbworld.org/forums/c-clas...-pictures.html |
#21 |
I was just told that the $93 was for a single door pin. Yea. But I will confirm that once it shows up.
__________________
#22 |
Drives: R8
So even the official AMG door pins aren't "plug and play"?
*faints*
__________________
Currently driving: 2011 R8 5.2 Gone: 2009 R8 4.2 | 2009 C63 AMG | 2006 S4 | 1994 NSX | 1992 NSX
#23 |
Drives: W204/W220
Is it possible to just order the front door pins? Just going to leave the rear ones intact. $93 for a single pin seems rather expensive?
#24 | |
Quote:
The AMG-made door pins (as seen here) are just about $93 per pin (not per set). The above prices are for other styles of pins that go for different prices. I'm also not sure about how the AMG pins will install - I'll probably let a dealer do the rear ones, so if they break the sleeve, they'll have to pay for it.
__________________
#25 |
Drives: 2009 C300 4Matic Sport P2/MM/Steel Gray
what ever happened to the video?
__________________
| Tags |
| 0228, 766, a000, a0007660228, amg, brabus, door, installation, lock, mercedes, pin, pins, service, video, w204 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
