Aftermarket wheel Thread.
#1851
^^ Very nice wheels! What brand & specs are they?
At first, I thought u had a 507. Lol
#1853
Yes, same tires and wheels on front and rear. Lowered with H&R springs... no problems at the front. On rear i had a litte bit rubbing in the area between rear fender and car body ...
#1858
Post some pics if you have, I almost went with the same finish.
#1861
Will put better pics up soon.
These are copy S65 / CL65 rims.
19 x 8.5 ET40 - 235/35 Front
19 x 9.5 ET48 - 265/30 Rear
Now i have to lower the car. Look at that wheel gap at the front!!!
#1863
Nice wheels & estate. Ur rear tires are meaty but the front could use some 245/35.
#1865
http://www.ebay.com/itm/161441014410...84.m1555.l2649
If anyone is interested my car is up for sale!Just thought id post it up here! Thanks!
#1869
AMG C63
#1872
Hey guys , I'm about to order a new set of Fiske wheels and wanted to be sure that if i went with below wheels on a lowered KW suspension I will not have any rubbing?
19x8.5 offset of 40 Front
19x9.5 offset of 51 Rear
#1874
I think you should be fine but watch your alignment settings. I measured my caster at ~ +13* and think that pushes the front suspension forward and out at the bottom joint. If you keep your caster ~ +10.5* you will have more room and might even fit a 245/25/19 on the front. I ran a 275/30/19 on the rear and did not seem to rub much more than I do now on the right rear. The left side on my car seems to have more clearance for some reason.
You may have to adjust the ride height on your coil-overs as well. I am running H&R springs with stock pads in the rear.
#1875
