C63 AMG (W204) 2008 - 2015
Header Types Defined/Discussed + Photos of all C63 Headers and Manifolds
Old 08-13-2014, 02:12 AM
  #201
Former Vendor of MBWorld
MBH motorsports's Avatar
C63, SL55, E55, CLS55, ML63, C55
I dont like the way that looks. Let me get you a drop bar and a new Xpipe. Something like this is not your fault and you should have a system that fits and flows as we intended.
Old 08-13-2014, 08:19 AM
  #202
VaclavSV's Avatar
2012 C63 AMG Black Series
-Where Do I get high flow cats? Which ones work well with the MBH LT Headers?
Old 08-13-2014, 08:59 AM
  #203
Mort's Avatar
Mike has mids with high flow cats. Get them from him. Did you get an x-pipe?
You will love the MBH headers. They are reasonable for daily driving if you ease into the throttle, use low throttle angles and keep the revs below 2500. I you stab the throttle or open it up too much it will talk to you and everyone around. I have catted mids and an x-pipe with stock resonator and mufflers. I have an EC tune with the headers and it is an amazing car to hear and feel. The shifts at wot red line are incredible in C or S mode.
carlssoncclass that is a fine mess your installer made. Take Mike up on his offer and maybe do this to your installers head.....
Old 08-13-2014, 09:16 AM
  #204
VaclavSV's Avatar
Thanks mort! I will have to talk to Vlad at Eurocharged and see what Mid-pipes he ordered -He might be able to ask mike for the mids with high flow cats.
This post has made me feel more comfortable and excited with the header install! haha
Old 08-13-2014, 12:35 PM
  #205
carlssoncclass's Avatar
Thank you very much and PM sent! Please check and will look forward for your reply.
Old 08-13-2014, 01:25 PM
  #206
No problem, I'm pretty sure I got both items in stock. Checking my PM's now.
Old 08-13-2014, 08:24 PM
  #207
mr747's Avatar
c63
Let me try to take that off first, and I will let you know if I need a drop bar to be made.
Oh, and one stupid thing my shop did is that they bend the X pipe a little bit so that they can re-install back the horizontal metal piece when they first try to install the xpipe. Do you think this is a big concern / problem that it will affect the air flow? Please see the picture below. Thank you very much for the after sales service.
IMG_3752 by NIĆØ, on Flickr
IMG_3753 by NIĆØ, on Flickr
IMG_3754 by NIĆØ, on Flickr
what idiots
Old 08-14-2014, 09:35 AM
  #208
Kriston's Avatar
C63 AMG
This installer needs to be shot.
[QUOTEIMG_3752 by NIĆØ, on Flickr
IMG_3754 by NIĆØ, on Flickr[/QUOTE]
Old 08-16-2014, 03:00 AM
  #209
Rolf de Graaff's Avatar
C 63 AMG PP
[/B]Log-style Manifolds (Eurotech)
I have a set of log style manifolds with a crack in it. Are they worth to repare (I own a weld shop) or don't they give ant hp gain?
Old 08-17-2014, 07:50 PM
  #210
Mort's Avatar
Here is a link to a post by Superlubricity that shows what you might expect from log manifolds. He tested PLMs and got ~ 12RWHP.
https://mbworld.org/forums/c63-amg-w...folds-c63.html
Old 09-09-2014, 12:41 PM
  #211
Mr.Shift 63's Avatar
C63 AMG
Are there any other real lth for a 3 inch exhaust out there besides mbh and mhb?
MBH Headers are top notch but i´m looking for a design like the MHB headers...
Old 09-21-2014, 09:49 AM
  #212
dilandilan's Avatar
Scania
that is a nice topic....thank you for that
Old 10-07-2014, 08:36 PM
  #213
Bazman's Avatar
2013 AMG C63 Coupe 507
Those Supersprints are a work of art.
Old 12-08-2014, 07:48 PM
  #214
Bazman's Avatar
I've gone with DPE in Australia. True merge collectors with race spike inside. RAted to support 750hp. 409 stainless. Good for right hand drive.
And... no welds inside the primary pipes or inside the flange ports. All welds are on the outside so there is no flow disturbance from surface imperfections (welds create eddies).
http://dpe.net.au/index.php?route=pr...ory&path=44_56
No pics on their website yet - but quite a few sets out there now and great results. I believe the fastest C63 in Australia runs them.
Old 12-09-2014, 02:19 PM
  #215
KillaC63's Avatar
C63 & CLA45 AMG
Good that there are some RHD options!
Personally I'd want my headers welded at the flange on both the inside and outside of the primarys. Inside welds are typically ground or polished down, this ensures no leaks at the flange ever. Also having welds on the inside will make sure that the transfer of exhaust from the flange to the primary fills any any gaps, which there have to be where a primary mates a flange you are looking at two perpendicular pieces of steel.
Out of curiosity what does's the fastest C63 in Australia run vs the LHD world?
Old 12-11-2014, 07:21 PM
  #216
Bazman's Avatar
A lot comes down to the quality of the materials used and the welds. We will see.
Of the headers I've seen for the C63 - I do not like the welds jutting into the flow, they are not even, and as they are not hand finished, they are ugly and will create eddies.
The abrupt transition from port size to larger primary size without any inside welds to create jumps - actually helps reversion. The ultimate headers would have a port extension and the primary pipes would be flared over the top to create an air gap all the way around the port extension... that is a true anti-reversion header. But no body makes those other than as a custom made piece. F1 uses port extensions. It helps broaden the power band due to less reversion.
The Aussie car runs 11.5 at 121mph with headers and a tune to my knowledge. He ran 11.9 with IPE headers and a different tune.
Old 12-11-2014, 10:19 PM
  #217
RNS-11Z's Avatar
09 C63
That would be me. Dpe are the only company to make true lth for rhd c63's. They are of great quality and price.
Old 01-01-2015, 10:14 PM
  #218
C63TSgt's Avatar
2009 C63
How have I not seen this yet. Doing the conversion from Australian dollars to US...mean they are $690US????? Are there pics of these anywhere? They have two different part numbers, one that seems to be for RHD, and one for LHD. If this is the case, obviously shipping will be more, but not anywhere enough I'm assuming to be even close to the cheapest LTH here! Anyone have any info in those regards?
I just refuse to pay $2k+ for a set of headers knowing every other set I've bought hasn't even been close to that much.
Old 01-19-2015, 06:27 PM
  #219
Southways's Avatar
C63 Coupe, 2014, 507
I have not seen a set in person, or heard the tone, but noticed these on a web site:
http://xforce1-px.rtrk.com.au/bolt-o...cid-1063040129
I have installed a few X-force kits on Holdens - they are okay but not great. Typically very loud, and some models drone.
Old 01-20-2015, 12:32 AM
  #220
Sincity's Avatar
I've had mine out for years, as well as most everyone else who has our headers. Including cars that have over 650 wheel horsepower. No issues. If you want I will make you a drop bar
How much is the modified drop bar? I have your X-pipe and they had to remove the stock bar.
Old 01-20-2015, 03:35 PM
  #221
kb24forlife24's Avatar
None for now
Here is a video of a C63 with iPE headers and iPE valvetronic full exhaust. It has a very aggressive growl and is super loud.
Old 01-21-2015, 06:54 PM
  #222
Sincity's Avatar
I couldn't live with that sound.
Old 01-23-2015, 02:49 PM
  #223
I am Jeff's Avatar
Steel Grey Metallic C63!!
You'll love the sound of the ARH/MHP setup! It sounds pretty stock once the car is warmed up, but with a deeper grumble sound when it's idling. Unless you get on the gas, it's stock sounding below 2500 rpm.
Old 01-23-2015, 04:31 PM
  #224
Kriston's Avatar
C63 AMG
IMHO you need a quality catback with any LTH. The stock exhausts are tuned to a higher frequency, under WOT they come apart. Like someone playing a trumpet too loud.
Old 01-26-2015, 11:04 AM
  #225
akmatic63's Avatar
10 C63, 06 S65, 14 ML350, 95 S500
Ordered MBH headers last week! Cant wait to get them in. I already have an MBH pipe, and a custom mid pipe to replace the secondary cats. Expecting to get the primary cats out as well. Still have mufflers on. Good thing this isn't my daily driver!!!
Does anyone have any recommendations for reliable/experienced shops in the central florida area? thanks
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Header Types Defined/Discussed + Photos of all C63 Headers and Manifolds
