Running H&R Springs and H&R Spacers?
C63 Edition 63 / Z4M Coupe
Is anyone running H&R Springs and H&R Spacers on the stock 19" AMG Wheels. If so what's your opinion and post some pics.
i have h&r springs, all good so far. but by spacers do you mean wheel spacers?
I have the 19" AMG wheels and was thinking of going with a set of H&R springs and some H&R wheel spacers.
My questions are:
1. how does the car ride with the H&R Springs compared to stock - I don't want to compromise ride comfort especially on 19's
2. Is there excessive camber once the springs are installed resulting in the tires scrubbing out the inside edge.
3. What size spacers are appropriate for the front and rear without the risk of rubbing, if the car is lowered on H&R Springs and has the 19" AMG wheels
Cheers
Check out this thread
https://mbworld.org/forums/c63-amg-w...ls-anyone.html
There is no problem to run both, i've drive this setup and i did nothing with the body of my car
My questions are:
1. how does the car ride with the H&R Springs compared to stock - I don't want to compromise ride comfort especially on 19's - rides perfect. like factory. you wouldnt even notice the difference. i too have 19s fitted.
2. Is there excessive camber once the springs are installed resulting in the tires scrubbing out the inside edge. - on the front you will need a wheel alignment otherwise the inners will get done quicker. in saying that i havent had a wheel alignment done yet. also i have 19x10s on the rear, with 5 people in the car (ea over 100kg) and boot full of luggage, didnt scrub at all.even going up driveways on an angle.
3. What size spacers are appropriate for the front and rear without the risk of rubbing, if the car is lowered on H&R Springs and has the 19" AMG wheels - to be honest i wouldnt recommend spacers at all. ive had issues previously on other cars with them eg nut breakage, hi speed vibration
