C63 AMG (W204) 2008 - 2015
Hard acceleration in 1st Gear = red "1 UP" in the speedometer??
Old 02-13-2011, 06:13 PM
badu's Avatar
Hi guys, I am just a little concerned to see a red "1 UP" message (actually the whole speedometer turns red) when I am doing hard acceleration in the 1st gear in M mode. My car only has 2k miles and I haven't really pushed it too much, but I don't see the same message in any other gears? Is this normal?
Old 02-13-2011, 06:14 PM
GHAZAN's Avatar
MBUSA
change gear
Old 02-13-2011, 06:20 PM
callmiro's Avatar
2016 C63 S
It's called a Shift Light
It will do it in every gear when you get close to the optimal shift point or redline
It's there so you don't have to look at the tach to shift
Old 02-13-2011, 06:52 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Change your diaper light.
Old 02-13-2011, 06:59 PM
E500C70's Avatar
B200, C70 HPT Coupe
I had to
Old 02-13-2011, 07:01 PM
black-clk500's Avatar
'14 911S (garage queen) '13 X3 (family hauler)
totally normal, happens to me every time I go WOT
it is a little unnerving, but I don't think it does any damage, I can't believe it took you that long to "see the light"
Old 02-13-2011, 07:02 PM
ZephyrAMG's Avatar
Welcome back buddy, We missed your sexy ***...
Old 02-13-2011, 07:03 PM
thanks, glad to be back
Old 02-13-2011, 07:06 PM
ZephyrAMG's Avatar
The weather has gotta to be getting better over there so we expect a full report on your P31 beast as you stretch her legs this spring...!
Old 02-13-2011, 07:08 PM
still have a ton of snow on the ground, I thought it would never stop!
I can't wait to get out there again, it will be like getting a new car all over again
Old 02-13-2011, 07:12 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Don't worry, if you continue to bounce it continually off the limiter it'll eventually change itself.
Old 02-14-2011, 01:21 AM
C63newdude's Avatar
C63 AMG
Not on manual mode. It will stay on whatever gear you are.
Old 02-14-2011, 10:59 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I have not tried it.. but does the limiter not kick in when you hit the maximum redline RPM's
Even true manual clutched vehicles do that, its the self preservation mode that almost every new engine I know of has.....
In case no one has actually hit the limiter, usually you lose all power for a very short period and the rpm's drop, at a certain point, probably around 2 to 3k below redline, you regain power (atleast my VW did that).
Old 02-14-2011, 11:07 AM
Sincity's Avatar
+1
Old 02-14-2011, 11:36 AM
Originally Posted by Sincity
+1
Thanks Sin, I'll try to keep it clean, no pun intended
Old 02-14-2011, 12:58 PM
MiamiAMG's Avatar
C63
It's a shift light. It's letting you know that it's time to shift gears! Now!
Old 02-14-2011, 02:03 PM
azadian22's Avatar
09 C63
I have noticed when you don't drive the car that hard theshift lights will be at differant points...like after driving normal for a week or more the lights will come on at a lower rpms then when I reset the tcu. Has anyone else notice this? Or did I just think that was happening and not realise it?
Old 02-14-2011, 09:20 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
When I tried it on Manual, braking drops my gears, but it won't shift up unless it bounces off redline too much correct? Letting it shift itself doesn't have a sonic boom effect. I love downshifting...but I get about 5 miles a gallon. And welcome back BLACK CLK! Finally got my car bish!
Old 02-14-2011, 09:21 PM
GHAZAN's Avatar
MBUSA
there is no tcu reset for our car unless you pull the battery maybe....mine was about 5600-5800krpm today, little low
Old 02-15-2011, 09:00 AM
azadian22's Avatar
09 C63
Sorry I thought wheb you reset the ecu,(turn the key, hold the gass ect.) It reset both the tcu and ecu but it must be just the ecu but I'm still almost positve that, that would change the shift points.
Old 02-15-2011, 09:02 AM
jvanbrecht's Avatar
There is a reset for the TCU, you cannot reset the ECU. TCU is just for the transmission, the ECU controls the entire vehicle..
Old 02-15-2011, 09:33 AM
azadian22's Avatar
09 C63
Okay so I was right the first time, I knew one of them can be reset.
Old 02-15-2011, 09:48 AM
bushburninc63's Avatar
2009 c63, 2010 E63
so what is the proper method to reset the tcu? I've read differing answers. Some said it can be done and other said it can't.
Old 02-15-2011, 11:01 AM
Sheep's Avatar
2013 Nissan GT-R BE
Take off the start button; use your key to turn to position two (2) just before engine start; fully depress gas for 5-10 seconds; turn the car off and wait for at least 2 minutes.
Sheep
Old 02-15-2011, 12:34 PM
GHAZAN's Avatar
MBUSA
There is no sneaky reset for these cars with gas pedals or turning keys
Quick Reply: Hard acceleration in 1st Gear = red "1 UP" in the speedometer??
