C63 AMG (W204) 2008 - 2015
engine blown at 23,000
Old 02-21-2011, 08:23 PM
kidjnco23's Avatar
09 white c63 amg
so last week i drove to work like i normally do parked my car got out didnt beat on it or anything, got out of work started my car and check engine light was flashing and the car was chugging violently like it was misfiring. had it towed to my local mb dealer and spoke to them today luckily i know the mechanic so i spoke to him personally and he said all 8 cylinders were misfiring and theres no compression on one side of the motor just waiting to find out if their going to replace it or wat, this happen to anyone else??
Old 02-21-2011, 08:28 PM
GHAZAN's Avatar
MBUSA
sounds like one of those purge valve sensor issues, good luck
Old 02-21-2011, 08:31 PM
mthis's Avatar
Anything W/4Wheels
i say 02 sensors
Old 02-21-2011, 08:44 PM
GHAZAN's Avatar
MBUSA
clogged cat?
Old 02-21-2011, 08:47 PM
kidjnco23's Avatar
09 white c63 amg
there are no secondary cats or reonators you think this could of caused it because i dont want them to try to put the blame on me!!
Old 02-21-2011, 08:52 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
Most likely failed cam sensor(s) or one or more cams are out of sync with the crank. Happened to me but because of the tune I had to pay for the cams to be "re-learned". Wasn't bad, just two hours of labor after MB replaced two cam sensors under warranty that were probably working fine.
Old 02-21-2011, 08:54 PM
hhughes1's Avatar
Reminder to all if the CEL is blinking then it is NOT an emissions issue and you should stop driving asap.
Old 02-21-2011, 09:04 PM
_AMG_'s Avatar
C63
Do you have a tune?
Could be spark plugs?? but I doubt it. Just throwing it out there.
Let us know what the problem was.
Old 02-21-2011, 09:11 PM
kidjnco23's Avatar
09 white c63 amg
Na no tune and all 8 cylinders were misfiring when he pulled up the codes!
Old 02-21-2011, 10:04 PM
VCA_AMG's Avatar
'15 E63S wagon
This isn't a 'blown engine,' it sounds like an electronics problem. With any luck they'll get it sorted quickly.
Old 02-21-2011, 10:20 PM
kidjnco23's Avatar
09 white c63 amg
Hopefully bben there since las thursday!
SonnyakaPig's Avatar
MB
Wow, OP, I really feel for you. I hope it isn't a blown motor. And I hope they cover it under warranty.
Please let us know what comes of this.
Old 02-21-2011, 10:21 PM
MB
The point you made in the other thread about maintaining the warranty really resonates.
Old 02-21-2011, 10:29 PM
kidjnco23's Avatar
09 white c63 amg
Def will let u guus kno!
Old 02-21-2011, 10:37 PM
kidjnco23's Avatar
09 white c63 amg
I just hoped I dont get screwed and they try to say something about me not having the secondary cats and res replaced with straight pipes!
Old 02-21-2011, 10:44 PM
GHAZAN's Avatar
MBUSA
you dont even have a tune, your warranty stands of course...your car is practically stock minus 2ndary cat delete which is nothing
Old 02-21-2011, 11:37 PM
MB
I agree. Who would have thought?
I mean, the dealership may try to say something, but their argument would likely seem attenuated. *think that's how you spell that word.
Old 02-21-2011, 11:46 PM
kidjnco23's Avatar
09 white c63 amg
Well I hope so!
Old 02-22-2011, 12:16 AM
MB
Where is the purge valve located? Mine was sticking open so they replaced it.
Old 02-22-2011, 08:43 AM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I had a CEL, and had my purge valve replaced as well, there is a TSB out on this. Apparently there is a new purge valve out there that replaces the old part.
Old 02-22-2011, 09:37 AM
jza80's Avatar
If the CEL is blinking, that means the OBD system detects misfire. That's the only reason it can blink. If your cam pos sensors got out of alignment, that could do it as well as cause no compression on the one side.
Good luck!
Old 02-22-2011, 01:01 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Actually.. they can void the warranty.. while they may or may not is a different story. Removing the cats and resonators changes the back pressure dynamic of the exhaust system, which directly relates to how the engine performs. Removing those, changes how it was designed to function, as a result, they could deny a warranty claim.
On the other hand.. if you changed the radio and the engine blew up, well they have to fix the engine under warranty.
Google magnus morrison act
Old 02-22-2011, 01:05 PM
GHAZAN's Avatar
MBUSA
No they cant. Catback modifications to exhaust do not alter warranty. Removing your 2ndary cats will likely void his emission warranty if they are real ****, but shouldn't affect his primary cats or o2 sensor warranty since it was done after. You don't lose everything. If anything he has less backpressure, which doesn't effect anything really except perception
Old 02-22-2011, 02:20 PM
tipsyhemi's Avatar
335i, 899, 750li, the titanic
did you actually read the magnus morrison act before you clicked "submit reply"?
Old 02-22-2011, 02:26 PM
jvanbrecht's Avatar
I have actually read it a number of times, the basics of it is that they cannot void the warranty on something that uses after market parts (amongst other reasons) unless the damage resulted from those aftermarket parts. Modifications on the other hand are not covered, and I would gather that modifications (whether or not we all agree with the fact those modifications did not harm) to the exhaust system, which is a key component of the engine systems, could result in MB denying a claim on the engine.
You of course have every right to contest this, and attempt to get MB to warranty the engine, but that will be time consuming and costly.
Quick Reply: engine blown at 23,000
