Passenger Airbag light??? how to clear
I removed my passenger seat recently and decided to put it back in. I thought the Passenger airbag sensor would reset after reinstalled, but it hasn't. Any idea how to do it - pull battery, dealer, etc?
I have an autoenginuity tool if it helps, but it's not showing as a 'code' when I load it up, so there is nothing to clear technically.
bump...
Also anyone have the autoenginuity tool? Is it possible to monitor AFR with this thing. I read the manual at it said change the scale value to 14.7. How accurate is this thing and which O2 sensor should I choose - O2 equivalence ratio, O2 sensor voltage, or O2 sensor fuel trim?
bump...
The other way to clear this is to go to a dealer.
thanks mthis. Sucks that the basic scan tool doesn't cover this code. Anyone in Socal/LA with the mercedes expansion want to clear my code, I'll chip in some $. Rather not go to the dealer.
btw, battery disconnect didn't work.
Call Hyevon Motors in Huntington Beach....Serge used to be an AMG tech mechanic at Penske...now he owns Hyevon Motors.
