C63 AMG (W204) 2008 - 2015
Tire width for 19s
Old 03-17-2011, 10:39 AM
Exacc's Avatar
E46 M3, '09 C63
Tire width for 19s
I'm looking to upgrade to 19s and see a lot of people do 245/275 width for 8.5 and 10 rims.
However am I correct in saying that 245/265 is actually closer to stock specs and a better fit for an 8.5 and 9.5 rim?
Anyone ever compared 245/265 vs 245/275?
Old 03-17-2011, 10:59 AM
olszowa12's Avatar
'08 C63 Estate
I've tried all possible setups on my 19" Multispokes:
-235/245
-235/255
-235/265
-235/275
-245/255
-245/265
-245/275
... and the only difference I saw was the height of the tire sidewalls...
Old 03-17-2011, 11:04 AM
KEMA's Avatar
2012 E63 PP, 2012 Ferrari 458, 2012 Boxster S
The only difference I saw was increased traction
275s all the way unless you are running lower springs / coilovers in which case you may experience rubbing.
Ken
Old 03-17-2011, 11:22 AM
BK63amg's Avatar
'16 GTS Solar
I'm actually in the same position...I was hoping I could run 245/275 on the stock suspension without rubbing.
Any opinion on the profile? Do you guys think I'll have any issues with the computer if I run a 35 profile front and rear? NYC roads are rough...and I've hear people complaining about traction control kicking in if the aspect ratios are off.
Old 03-17-2011, 11:24 AM
63c
63c's Avatar
2009 c63 + 2017 coupe c63 edition1
19s AMG go with 245/265 save and good for lower 2 as my car is
Old 03-17-2011, 12:14 PM
CELLryuu's Avatar
C63 AMG Coupe P31
Im in the same boat as well. im going with 19 245/275. I have not ordered my set up yet but Ive asked this question to many people and on stock suspension there is no rub as long as you get your off-sets right.
This is just a gauge ive come up with so far but dont know if its going to work yet.
Front off-set +38 to +43
Rear off-set +50 to +54
This is what ive come up with through inquiry. Comments?
Old 03-17-2011, 12:25 PM
Exacc's Avatar
E46 M3, '09 C63
Aren't stock offset
45 front and 54 rear?
Right offset depends on the width of the rims...
Old 03-17-2011, 01:17 PM
CELLryuu's Avatar
C63 AMG Coupe P31
Originally Posted by Exacc
Aren't stock offset
Oh, yes...im sorry, with 8.5 front and 9.5 rear. This is just observations from what others have done on this site.
Thank you for pointing that out.
Old 03-17-2011, 01:56 PM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
The biggest issue i can see with the front tires, is that if there too wide, the tire could actually hit the spring purch. As for the rears, rubbing the fenders. I run a 235/40 and a 265/35 on stock wheels. But on my E63 245/35-19 and 275/30-19.
Old 03-18-2011, 03:11 PM
JeffDL's Avatar
C63
On my H&R spring lowered car I run:
19x8.5 et35 with 245/35's
19x10 et55 with 275/30's
ZERO rubbing anywhere have put over 1,000 miles on this set up and again ZERO rubbing.
Tire brand is important if you plan on lowering, not all tires are the same size even if they are the same size.
Old 04-29-2011, 10:38 AM
azadian22's Avatar
09 C63
Dose any one know if a front 245/35-19 and rear 275/35-19 won't rub? And fit the stock 19's?
Old 04-29-2011, 02:00 PM
Muskoka_AMG's Avatar
2008 C63
you'd want 275/30 19
Old 04-29-2011, 04:58 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
You need 275/30/19's for the rear. I have 245/35/19 for my fronts and 275/30/19's for my rear. No rubbing whatsoever.
Quick Reply: Tire width for 19s
