C63 AMG (W204) 2008 - 2015
Eurocharged Power Pulley 63 AMG
Old 04-08-2011, 07:54 AM
jacob502's Avatar
2008 C63 ,2009 SL 63 AMG, 2011 SLS AMG
Arrow Eurocharged Power Pulley 63 AMG
Has anybody ordered this Power pulley from this provider? Is it any diffrent from the one that Evosport has?. Seems like the same material. I wonder if anybody tested them on a dyno and found any gains.
Old 04-08-2011, 08:53 AM
qship5's Avatar
M5, C63, 335Ci
I'm sure Jerry or someone else from Eurocharged can chime in and provide some info and possible dyno charts.
Old 04-08-2011, 09:13 AM
propain's Avatar
See Sig
Save your money... or put it somewhere else.
Old 04-08-2011, 10:47 AM
jacob502's Avatar
ineresting
why?
Old 04-08-2011, 11:21 AM
BO Knows's Avatar
2010 C63, 2007 X5
For a pully and the labor costs, the HP gains are not worth it for it's value. You rather go with a tune or save up for LT Headers.
Old 04-08-2011, 11:29 AM
bluejae's Avatar
'10 C63
what if you have LT and a tune?
Old 04-08-2011, 11:30 AM
Speedriven1's Avatar
Speedriven
I'm the guys at EC have before/after runs?
Old 04-08-2011, 11:49 AM
Sincity's Avatar
Huh???
Old 04-08-2011, 11:52 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Originally Posted by Sincity
Huh???
Sounds like one of those gator-catcher guys talking...
Speedriven
Huh???
OP asked "I wonder if anybody tested them on a dyno and found any gains." and I was trying to say that the people selling them should have before/after dyno runs.
Old 04-08-2011, 12:05 PM
jacob502's Avatar
Cost is not an issue. Are the gains real?
Old 04-08-2011, 12:39 PM
BO Knows's Avatar
2010 C63, 2007 X5
As noted on this thread, pulley does give a little gain:
https://mbworld.org/forums/c63-amg-w...-2010-c63.html
Here is also some good reading materials:
http://www.abedinmotorsports.com/faq.htm
Old 04-08-2011, 01:54 PM
qship5's Avatar
M5, C63, 335Ci
+1...I'd like to know if the gain is noticeable for people with these mods already.
Old 04-08-2011, 06:46 PM
propain's Avatar
See Sig
I don't think Mike or Dads run it. Ask yourself why. From my understanding the stock one is better.
Old 04-08-2011, 07:01 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
+1 The hassle is not worth the possible gains.
ineresting
why?
Although some people have seen some gains with the pulley on a C63, I have not (personally) been able to duplicate such gains on at least two different models on two different dynos. In fact, a couple of people experienced some electrical problems soon after the pulley install, which later was attributed to a bad alternator. Please research the pulley mod very carefully before using it on an SL63
Old 04-09-2011, 07:38 AM
jacob502's Avatar
Thanks for the heads up. I also heard that it damages the crank. I was hoping that the sponsor from Eurocharged would answer. Looks like he got nothing to add
Old 04-09-2011, 08:12 AM
khmergod's Avatar
2011 P31 C63 2015 CLA45
If it has a chance of being defective, why are they still sold?
Old 04-09-2011, 12:46 PM
jacob502's Avatar
Thats the one thousand dollar question. or wait, no, the 799 dollar question
Old 04-10-2011, 11:50 PM
Former Vendor of MBWorld
AMS Performance's Avatar
AMG
Edited:
Both are underdriven...
The Eurocharged unit is a great design, however as with ALL pulley installs... PLEASE BE SURE TO TAKE IT TO A BENZ SPECIALIST THAT KNOWS WHAT THEY HELL THEY ARE DOING! Any great part can be installed by an idiot and function improperly ....
Hope that helps,
AMS
Old 04-11-2011, 12:21 AM
Sincity's Avatar
Originally Posted by AMS Performance
There is a difference ... the evosport is underdriven, the Eurocharged is stock diameter.
At AMS we highly recommend only using stock diameter crank pulleys as it will not damage or decrease the life of the accessories. The stock 63 pulley is already under-driven from the factory, so to under-drive it even more is not a wise decision (as mentioned by alternator problems). The 63 pulley is by far the smallest diameter pulley benz has ever done and MB did this to improve the revving characteristics & top end power. In many ways they took a page out of the aftermarket book and applied it to the car directly from the factory.
The Eurocharged unit is a good design, however as with ALL pulley installs... PLEASE BE SURE TO TAKE IT TO A BENZ SPECIALIST THAT KNOWS WHAT THEY HELL THEY ARE DOING! Any great part can be installed by an idiot and function improperly ....
Hope that helps,
AMS
Thanks for the post. Do you know the weight difference between stock and the EC?
Old 04-11-2011, 02:29 AM
AL Hosani's Avatar
C 63
but, some ppl claim that they gained more power and they past 5k miles with 0 problems, so now what do we belive ?
Old 04-11-2011, 12:32 PM
AMG
Both pulleys are roughly in the 4.x lb range, stock pulleys are usualy 6.3-7.0 lbs depending. Ours are 2.8 lbs (6.3 pulley not released yet).
Hope that helps,
AMS
Old 04-11-2011, 01:03 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
While I agree with much of your post, AMS, I disagree with this part (from a technical standpoint). AMG's engineers designed the M156 crank pulley to be a certain size, which by itself doesn't mean much, but is useful to know in relation to the ratio of pulley size vs. the sizes of the various accessory pullies. The goal presumably to reach the optimal rpm ranges of the accessories, without over or underdriving them outside of their manufacturer-specified operating ranges.
As such, it isn't really possible to say something is "underdriven from the factory" - the factory drive ratio is the baseline from which to compare alternative solutions' merits. IMHO.
Old 04-11-2011, 01:11 PM
MB_Forever's Avatar
Some have had absolutely zero problems and others have had alternators go bad and/or other electrical problems (other 63 models). You make the decision whether the risk is worth the gain
Old 04-11-2011, 04:15 PM
AMG
Correction: Post has been edited.... both are underdriven.
The only real difference I guess is that eurocharged pulley will ship within a couple of days ... Evo-sport may take significantly longer
Hope that helps,
AMS
Quick Reply: Eurocharged Power Pulley 63 AMG
