Weistec Supercharged M156 CLK63 Black Series Dyno Results
Preliminary Weistec Supercharged M156 CLK63 Black Series Dyno Results - 640 wheel horsepower
Published on 04-15-2011 07:06 AM 15 Comments Here are the preliminary results for JRCART's CLK63 Black Series running the Weistec supercharger. The car has the Weistec race supercharger package which includes the Weistec heads, cams, and fuel system including larger injectors. The car ran 14.5 psi of boost on stock internals which is incredible really. That is a lot of boost for the stock internals to handle. The tires were slipping on the dyno due to the power which can be seen in the graph so these are just preliminary results. They will be trying again with new rubber in the next few days and likely hitting the 7XX whp range.
CLS63
Please do tell... Did he increase the head gasket thickness?.. running with stock compression 14.5 psi should destroy the motor almost instantly and if not then these 63 motors are not what we all thought they were A 250 shot of nitrous should be ok then
I've hit the 612rwhp a few times but stopped the runs , wasn't sure how high the #'s would go before something bad happened..
Done deal, Fontana one week from today. Here's the link to the event that I posted in Events section.
https://mbworld.org/forums/events-ga...4-22-11-a.html
