C63 AMG (W204) 2008 - 2015
Winter Tire size, 255/40/18 is fine?
Old 05-10-2011, 09:51 PM
jwkim80's Avatar
2011 C63(Euro-spec)
Hello.
I know it's spring but one of my buddy is selling his 99% brand new winter tire from his Porsche.
It's 235/40/18 & 255/40/18.
I know fronts are fine but rear tires are little tall for C63.
Just wondering if this set up is fine? or ESP will engage often?
Should I just pass the deal?
TIA!
Old 05-11-2011, 10:05 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Ideally, you want to use skinny tires in snow that cut into the snow, and place more pressure and weight on a smaller surface area to get better traction in snow.. 235, or even 225 all around is what you want for snowy areas.
Go read this.. http://www.tirerack.com/winter/tech/...jsp?techid=126
Old 05-11-2011, 10:10 AM
JeffDL's Avatar
C63
I ran 235's all around on stock wheels last year and it looked a little odd. Going to try and find 255's for the back this winter. Also managed to rip right through the rears in like 3k miles.
Old 05-11-2011, 10:21 AM
Interwebz's Avatar
2010 C63, 2002 Corvette Z06
i run 225s on all corners.
Old 05-11-2011, 10:27 AM
jvanbrecht's Avatar
It's winter.. your not exactly going to be racing it (well I hope not).. at least not in the palces where winter sucks.. ie the North East... go with the most narrow tire possible for the duration, or you will just end up spinning your tires alot and eating them up much quicker..
Old 05-11-2011, 03:40 PM
wadgras44's Avatar
2009 c63
fellas, not that your width comments aren't valid but I think the 40 (vs. OEM 35) sidewall issue is the OPs concern.
And I unfortunately, I don't know the answer.
Old 05-11-2011, 09:09 PM
jwkim80's Avatar
2011 C63(Euro-spec)
Yes, I meant the sidewall profile.
Anyone?
Old 05-11-2011, 09:21 PM
coladin's Avatar
2014 C63 507, 2012 R350
Anyone?
You'll be fine, if they were 45's the profile percentage would be way off. I have run winters that were different marginally. Any tire shop should point out what is right or wrong. I thinkg it's fine.
Old 05-11-2011, 09:53 PM
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Ran 235s. I don't know how much snow u get but 255 is not optimal. Get a wheel/tire combo for the winter. Also good because u can rotate as well
Old 05-15-2011, 09:06 PM
jdbassman's Avatar
2011 c63
Will 225/45/17 fit ?
Old 05-16-2011, 12:47 PM
jvanbrecht's Avatar
Only if you have 17" rims.. I would not put those on the 18 or 19 AMG rims that the AMG's come with.
Old 05-17-2011, 03:35 PM
BK63amg's Avatar
'16 GTS Solar
I could be wrong but I doubt 17" wheels will clear our BBKs...
Quick Reply: Winter Tire size, 255/40/18 is fine?
