C63 AMG (W204) 2008 - 2015
hi, jus purchased c63
Old 05-17-2011, 05:00 PM
c63nav's Avatar
c63
hi, jus purchased c63 a; can any one tell me what temp it sould be running at
Old 05-18-2011, 07:42 AM
Savoy6's Avatar
09 C63
on the amg screen i usually have 215-224 195 if i remember correctly.
Old 05-18-2011, 08:01 AM
khmergod's Avatar
2011 P31 C63 2015 CLA45
175f is when car is warmed up for engine. It should constantly run at around 210-225 in most climates and water should be 180-200. My personal numbers in Houston, TX.
Old 05-18-2011, 08:51 AM
GBlansten's Avatar
2017 BMW X5M DG/AB
A lot of these questions have come up before. Search can be very helpful. I suggest this in a friendly way. This webforum is loaded with good advice.
You will likely have questions when your car gives you a low oil level warning or the TPMS system says low tire pressure. You may get a low coolant warning. Also the rear tires will likely only last 5-6K miles.
Congrats on your car.
Quick Reply: hi, jus purchased c63
