C63 AMG (W204) 2008 - 2015
Some tire options
Old 06-20-2011, 08:19 PM
DD GT3 RD's Avatar
'11 C63 w/ P31
Some tire options
Here are the options. I believe the car has 18x8 and 18x9 rims and stock tire size is 235/40/18 and 255/35/18.
So I could move up a little in size, but I know moving to a much grippier/softer tire will make a nice difference alone. I worry if I go wider the rim isnt wide enough and with a car of this weight it will make the sidewall flex/fold in high speed cornering/tracking. So either stay stock size or go 245/40/18 and 265/35/18
-Hankook Ventus R-S3 are very cheap, I believe that the A/E Gintani Paul Walker race car run them on their car so they got to be good enough. Dont know much about them thou.
-I have run the RE-11 on the Mini Cooper S and I love them! Very stiff side wall w/ amazing turn in and this is what many say.
-The AD08 I dont know much about, hear they are comparable to the RE-11 but not as good turn in due to softer sidewall.
- Nitto NT05 dont know anything about
Nitto NT-05
245/40/18 - $160
265/35/18 - $215
Ventus R-S3
http://www.tirerack.com/tires/tires....el=Ventus+R-S3
235/40ZR18
91W
$189.00 (ea.)
245/40ZR18
97W
$164.00 (ea.)
255/35ZR18
90W
$235.00 (ea.)
265/35ZR18
97W
$216.00 (ea.)
RE-11
http://www.tirerack.com/tires/tires....=Potenza+RE-11
235/40R18
95W
$276.00 (ea.)
245/40R18
97W
$282.00 (ea.)
255/35R18
90W
$299.00 (ea.)
265/35R18
93W
$315.00 (ea.)
AD08
http://www.tirerack.com/tires/tires....VAN+Neova+AD08
235/40R18
91W
$237.00 (ea.)
245/40R18
93W
$247.00 (ea.)
255/35R18
90W
$263.00 (ea.)
265/35R18
93W
$266.00 (ea.)
Old 06-20-2011, 09:02 PM
blackc230benzo's Avatar
2010 C63, 2003 C230 coupe
Considering the price point/ kind of tires you are looking at you might also want to consider Nitto. I just put on some NT-01 and the grip is amazing!
Old 06-20-2011, 09:27 PM
DD GT3 RD's Avatar
'11 C63 w/ P31
The NT-01 is closer to strict track tire, at least more so than the RE-11 and AD08. I think those are more comparable to the NT-05 which I also looked at.
Added Nitto to the list.
Old 06-20-2011, 09:57 PM
Savoy6's Avatar
09 C63
245/265 star specs. air them to 39 cold and youre done looking for tires. they are as good as any of those you listed and better than any of those listed in the wet.
Old 06-20-2011, 10:16 PM
BerBer63's Avatar
2009 C63
I'm on my 2nd set of nt05s. i got your size if you want them.
Old 06-20-2011, 11:11 PM
DD GT3 RD's Avatar
'11 C63 w/ P31
I don't understand, u sell them? Or have an extra set u want to get rid off?
How much?
Old 06-21-2011, 12:26 AM
_AMG_'s Avatar
C63
Have you thought about the Dunlop Direzza Star specs?
Jeremy was running Nitto NT05's at one point im sure he will be able to fill you in about those tires.
Old 06-21-2011, 02:21 AM
DD GT3 RD's Avatar
'11 C63 w/ P31
I know he has the Ventus R-S3 in the rear right now.
Seems the Ventus r-s3 and the NT-05 are the cheapest and well a member on here has the NT-05 locally so might go with them.
Dunlop Direzza Star Spec
235/40ZR18
91W
$195.00 (ea.)
245/40ZR18
93W
$205.00 (ea.)
255/35ZR18
90W
$247.00 (ea.)
265/35ZR18
93W
$263.00 (ea.)
Old 06-21-2011, 03:26 AM
xtyper's Avatar
2013 E63 AMG
I just picked up a set of Michelin super sports for the rear 265/35/18 and couldn't be happier with the performance so far. $270 per tire and they hook amazing! You should definitely check them out. I'm very anxious to see how they perform at the upcoming buttonwillow track event.
Old 06-21-2011, 03:31 AM
_AMG_'s Avatar
C63
I'm thinking of picking up a set after I wear out my Hankooks.
Cheaper, grips better, and lasts longer then the PS2's, sounds like a winner in my book.
Old 06-21-2011, 04:01 AM
DD GT3 RD's Avatar
'11 C63 w/ P31
interesting, just did some research on them. Supposedly better than the PS2, which are good street tires but dont compare in terms of dry performance to what I listed above and the PS2 is very expensive around 350 for a rear, but 270 for the super sport is reasonable. Seems they really are pointing out how they are as good if not a little better than the PS2 in the dry but much better in the wet.
Although you can tell by the tread these are not on the same level as any of the tires I listed. But will probably last longer.
Dont think I can turn down a set of nt05 or ventus r-s3 tires for around 700-750 a set, these are pretty much track tires for the street.
I had the Bridgestone RE-11 on my GT3 and they were great, dont need to warm them up like an R-compound, but was way grippier than the PS2. Also have them on my Mini Cooper S and they just made the car so much better than the conti's, more grip, better turn in...
Old 06-21-2011, 07:14 AM
hhughes1's Avatar
2013 Chevy 427 Torch Red
http://www.caranddriver.com/reviews/...mparison_tests
Two year old comparison but many of the same players
Old 06-21-2011, 10:44 PM
blindfold's Avatar
C63
hope this helps, it is a comparison of extreme summer tires, RE-11 is ranked 1st currently
http://www.tirerack.com/tires/tests/...y.jsp?ttid=118
Old 06-21-2011, 11:03 PM
c63canada's Avatar
c63 amg
michelin supersport have a tread life warranty!!!
those are going to be my next tires.
check out this video:
http://www.youtube.com/watch?v=V7b18...feature=fvwrel
If the supersport can handle these car i guess they are good enough for my c63...
Old 06-22-2011, 12:46 AM
jsc1234's Avatar
2010 C63, 2014 E63
what does tread life warranty mean??
Old 06-22-2011, 01:24 AM
DD GT3 RD's Avatar
'11 C63 w/ P31
they could do that on any tire. But there is no question even the PS2 is one of the best street/performance tires just so expensive. Seems the Super Sports are 100+ less a tire. I just dont know how they compare in to outright dry performance to the above tires.
Old 06-22-2011, 02:29 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
The R-s3 should be considered a track or autocross tire.
They get crazy sticky. Here is a photo. Do not plan on getting any mileage from these. Street use, the rears are 5k tops. probably 10K on the front.
For the track I recommend them as near R compound with twice the wear.
Old 06-22-2011, 03:10 AM
Boost Gomez's Avatar
C63 AMG
I'm on my third set of Nitto NT05. 235/40 front, 275/35 rear.
Very pleased with them so far.
Old 06-22-2011, 03:45 AM
DD GT3 RD's Avatar
'11 C63 w/ P31
thanks boost! Are you on stock rims? I think im going 245/40 up front thou and 265/35 rear NT-05
Old 06-22-2011, 08:56 PM
c63canada's Avatar
c63 amg
The supersport are the only super high performance tires that have a pro-rated tread warranty to my knowledge.
in canada it's 55 000km and in the USA: I think it's 35 000 miles.
with stagered fitment like our cars, since you can't rotate the rear tires to the front, the rear tire tread warranty is only half so 17 500 miles.
Do the math: michelin supersport = great tires + if you wear them out in about 8000 miles you would get the next pair at around half off the price.
Old 06-22-2011, 09:10 PM
Faris63's Avatar
'13 CLS63 PP
My vote goes to Michelin PSS best tires I've ever had !
quite more tread than Hankook V12 and PS2 I've tried both
Old 06-22-2011, 09:41 PM
jsc1234's Avatar
2010 C63, 2014 E63
thanks for the info!does this apply even if you get them at tirerack?
Old 06-22-2011, 09:58 PM
c63canada's Avatar
c63 amg
you would have to call them up. Or maybe go to an autorized michelin dealer and try to get them to match the tirerack price.
Old 06-23-2011, 07:40 PM
C63 AMG
Stock wheels 10mm spacers front and rear.
Old 06-23-2011, 09:50 PM
dabullc63's Avatar
2009 C63 AMG
Nito NT555 - best for your money. The tires have super grip, great look and great wear rating. I have them on my 09 c63 and wouldn't think twice about getting them again. I went with the 235/40 front, 275/35 rear. Oh and definitely no ballooning.
Quick Reply: Some tire options
